Weatherunderground Alternatives
  • Pete
    Unrelated to your original post; moved the WUN and CWOP uploads stuff to the Cumulus software a while ago.
    http://www.findu.com/cgi-bin/wxpage....t=36&radar=***
    http://www.wunderground.com/weathers...p?ID=KILLOCKP1
    http://lockport.golffan.us/
    HS2 (Jon00's great scripting) creates this composite picture every few minutes:
    http://icons.wunderground.com/webcam...jpg?1387065533
    All of the HS internet weather stuff from the internet is via weatherxml these days.
    Weather stations (2 locations) just upload a text file to the internet and HS2 downloads the information from the cumulus weather stations.
    The 1-Wire environmental sensors send the data to HS2.
    I tested downloading weather maps from the NOAA satellites and it works well. (my direction with this stuff).
    The software, radio stuff can run on the HS2 box or just about anything relating to the satellite maps; like these pictures the best.
  • Pete
    Yea; been using weatherxml for a bit now; works great. (that is what I use for the HSTouch stuff).
  • Dafunktyfunk
    Re: Weatherunderground Alternatives
    Thanks, Pete!
    I actually switched and am now playing with weatherxml and am really happy with it.
  • Pete
    Tried the format above:
    api.forecast.io/forecast/apikey/41,-88.xml
    Doesn't work for me.
    I haven't tried the direct WUN RSS feeds in HSTouch but did try the following samples and they worked here for me.
    api.wunderground.com/api/apikey/forecast/q/IL/Chicago.xml
    api.wunderground.com/api/apikey/forecast/q/41,-88.xml
    api.wunderground.com/api/apikey/forecast/weather/q/41,-88.xml
  • Dafunktyfunk
    I am trying to insert weather into HSTouch using the information in Forecast.io
    I have an API but when I go and put in the Manual URL to RSS Feed, I get a "At 0, Root Element is missing." error.
    This is the syntax I am using:
    https://api.forecast.io/forecast/[$WEATHER]/[$LATITUDE],[$LONGITUDE]
    This is the example they post on their site:
    https://api.forecast.io/forecast/API...TUDE,LONGITUDE
    I of course updated the API in the HSTouch Server Setup in the HS Setup page.
    Here is a sample of what I get out of the API when placing it in a browser:
    {"latitude":38,"longitude":121,"timezone":"Asia/Shanghai","offset":8,"currently":{"time":1386125387,"summary":"Clear","icon":"clear-day","precipIntensity":0,"precipProbability":0,"temperature":50.52,"apparentTemperature":50.52,"dewPoint":39.53,"humidity":0.66,"windSpeed":13.37,"windBearing":257,"cloudCover":0,"pressure":1021.12,"ozone":319.83},"hourly":{"summary":"Breezy tomorrow morning.","icon":"wind","data":[{"time":1386122400,"summary":"Breezy","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":49.48,"apparentTemperature":44.4,"dewPoint":38.9,"humidity":0.67,"windSpeed":13.35,"windBearing":255,"cloudCover":0,"pressure":1021.22,"ozone":320.47},{"time":1386126000,"summary":"Clear","icon":"clear-day","precipIntensity":0,"precipProbability":0,"temperature":50.73,"apparentTemperature":50.73,"dewPoint":39.66,"humidity":0.66,"windSpeed":13.38,"windBearing":258,"cloudCover":0,"pressure":1021.1,"ozone":319.7},{"time":1386129600,"summary":"Breezy","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":51.85,"apparentTemperature":51.85,"dewPoint":40.34,"humidity":0.65,"windSpeed":13.49,"windBearing":262,"cloudCover":0,"pressure":1020.85,"ozone":318.55},{"time":1386133200,"summary":"Breezy","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":52.76,"apparentTemperature":52.76,"dewPoint":40.85,"humidity":0.64,"windSpeed":13.57,"windBearing":267,"cloudCover":0,"pressure":1020.58,"ozone":317.31},{"time":1386136800,"summary":"Clear","icon":"clear-day","precipIntensity":0,"precipProbability":0,"temperature":53.19,"apparentTemperature":53.19,"dewPoint":41.01,"humidity":0.63,"windSpeed":13.32,"windBearing":270,"cloudCover":0.01,"pressure":1020.43,"ozone":316.9},{"time":1386140400,"summary":"Breezy","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":52.93,"apparentTemperature":52.93,"dewPoint":40.72,"humidity":0.63,"windSpeed":12.52,"windBearing":273,"cloudCover":0.14,"pressure":1020.5,"ozone":317.79},{"time":1386144000,"summary":"Partly Cloudy","icon":"partly-cloudy-day","precipIntensity":0,"precipProbability":0,"temperature":52.18,"apparentTemperature":52.18,"dewPoint":40.09,"humidity":0.63,"windSpeed":11.32,"windBearing":275,"cloudCover":0.31,"pressure":1020.69,"ozone":319.49},{"time":1386147600,"summary":"Partly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":51.26,"apparentTemperature":51.26,"dewPoint":39.35,"humidity":0.64,"windSpeed":9.94,"windBearing":277,"cloudCover":0.44,"pressure":1020.85,"ozone":321.5},{"time":1386151200,"summary":"Partly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":50.33,"apparentTemperature":50.33,"dewPoint":38.61,"humidity":0.64,"windSpeed":8.42,"windBearing":278,"cloudCover":0.5,"pressure":1020.9,"ozone":323.84},{"time":1386154800,"summary":"Partly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":49.35,"apparentTemperature":46.49,"dewPoint":37.83,"humidity":0.64,"windSpeed":6.83,"windBearing":280,"cloudCover":0.51,"pressure":1020.9,"ozone":326.47},{"time":1386158400,"summary":"Partly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":48.36,"apparentTemperature":45.98,"dewPoint":36.97,"humidity":0.65,"windSpeed":5.53,"windBearing":283,"cloudCover":0.53,"pressure":1020.9,"ozone":328.8},{"time":1386162000,"summary":"Partly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":47.23,"apparentTemperature":45.11,"dewPoint":35.84,"humidity":0.64,"windSpeed":4.79,"windBearing":289,"cloudCover":0.56,"pressure":1020.88,"ozone":330.62},{"time":1386165600,"summary":"Partly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":46.01,"apparentTemperature":43.99,"dewPoint":34.58,"humidity":0.64,"windSpeed":4.35,"windBearing":298,"cloudCover":0.59,"pressure":1020.86,"ozone":332.13},{"time":1386169200,"summary":"Mostly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":44.97,"apparentTemperature":43.11,"dewPoint":33.64,"humidity":0.64,"windSpeed":3.94,"windBearing":315,"cloudCover":0.63,"pressure":1020.83,"ozone":333.3},{"time":1386172800,"summary":"Mostly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":44.27,"apparentTemperature":42.1,"dewPoint":33.28,"humidity":0.65,"windSpeed":4.18,"windBearing":347,"cloudCover":0.67,"pressure":1020.81,"ozone":334},{"time":1386176400,"summary":"Mostly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":43.8,"apparentTemperature":40.42,"dewPoint":33.27,"humidity":0.66,"windSpeed":5.78,"windBearing":12,"cloudCover":0.71,"pressure":1020.81,"ozone":334.37},{"time":1386180000,"summary":"Mostly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":43.45,"apparentTemperature":38.84,"dewPoint":33.36,"humidity":0.67,"windSpeed":7.91,"windBearing":25,"cloudCover":0.76,"pressure":1020.75,"ozone":334.8},{"time":1386183600,"summary":"Mostly Cloudy","icon":"partly-cloudy-night","precipIntensity":0,"precipProbability":0,"temperature":43.16,"apparentTemperature":37.53,"dewPoint":33.58,"humidity":0.69,"windSpeed":10.08,"windBearing":33,"cloudCover":0.83,"pressure":1020.47,"ozone":335.5},{"time":1386187200,"summary":"Breezy and Mostly Cloudy","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":43,"apparentTemperature":36.51,"dewPoint":33.94,"humidity":0.7,"windSpeed":12.33,"windBearing":39,"cloudCover":0.91,"pressure":1020.11,"ozone":336.27},{"time":1386190800,"summary":"Overcast","icon":"cloudy","precipIntensity":0,"precipProbability":0,"temperature":43.05,"apparentTemperature":35.95,"dewPoint":34.2,"humidity":0.71,"windSpeed":14.29,"windBearing":41,"cloudCover":0.96,"pressure":1019.94,"ozone":336.9},{"time":1386194400,"summary":"Breezy and Overcast","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":43.29,"apparentTemperature":35.85,"dewPoint":34.2,"humidity":0.7,"windSpeed":15.7,"windBearing":40,"cloudCover":0.98,"pressure":1020.25,"ozone":337.19},{"time":1386198000,"summary":"Breezy and Overcast","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":43.64,"apparentTemperature":36.04,"dewPoint":34.03,"humidity":0.69,"windSpeed":16.71,"windBearing":38,"cloudCover":0.97,"pressure":1020.85,"ozone":337.34},{"time":1386201600,"summary":"Overcast","icon":"cloudy","precipIntensity":0,"precipProbability":0,"temperature":44.02,"apparentTemperature":36.32,"dewPoint":33.85,"humidity":0.67,"windSpeed":17.53,"windBearing":36,"cloudCover":0.96,"pressure":1021.31,"ozone":337.8},{"time":1386205200,"summary":"Windy and Overcast","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":44.48,"apparentTemperature":36.76,"dewPoint":33.72,"humidity":0.66,"windSpeed":18.22,"windBearing":35,"cloudCover":0.97,"pressure":1021.61,"ozone":338.87},{"time":1386208800,"summary":"Windy and Overcast","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":45.03,"apparentTemperature":37.35,"dewPoint":33.63,"humidity":0.64,"windSpeed":18.76,"windBearing":34,"cloudCover":0.98,"pressure":1021.85,"ozone":340.24},{"time":1386212400,"summary":"Windy and Overcast","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":45.54,"apparentTemperature":37.93,"dewPoint":33.71,"humidity":0.63,"windSpeed":19.15,"windBearing":33,"cloudCover":0.94,"pressure":1022.02,"ozone":341.5},{"time":1386216000,"summary":"Windy and Mostly Cloudy","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":46.01,"apparentTemperature":38.5,"dewPoint":34.14,"humidity":0.63,"windSpeed":19.37,"windBearing":30,"cloudCover":0.82,"pressure":1022.03,"ozone":342.66},{"time":1386219600,"summary":"Windy and Mostly Cloudy","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":46.4,"apparentTemperature":38.99,"dewPoint":34.7,"humidity":0.63,"windSpeed":19.45,"windBearing":27,"cloudCover":0.66,"pressure":1021.95,"ozone":343.7},{"time":1386223200,"summary":"Windy and Partly Cloudy","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":46.48,"apparentTemperature":39.1,"dewPoint":34.86,"humidity":0.64,"windSpeed":19.44,"windBearing":24,"cloudCover":0.49,"pressure":1021.92,"ozone":344.1},{"time":1386226800,"summary":"Windy and Partly Cloudy","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":46.11,"apparentTemperature":38.63,"dewPoint":34.34,"humidity":0.63,"windSpeed":19.37,"windBearing":22,"cloudCover":0.31,"pressure":1022.06,"ozone":343.46},{"time":1386230400,"summary":"Windy","icon":"wind","precipIntensity":0,"precipProbability":0,"temperature":45.42,"apparentTemperature":37.76,"dewPoint":33.4,"humidity":0.63,"windSpeed":19.2,"windBearing":19,"cloudCover":0.13,"pressure":1022.3,"ozone":342.18},
  • Pete
    I have now added the uploading of weather data to the APRS/CWOP system. I did have issues relating having to open up some firewall ports both on the base W2003 standard server box and the firewall itself. Issues are that my preference are not to open up firewall ports for specific program uploading to the internet.
    It is not "fancy" like Weatherunderground; but you can see the data without having to log into the service or waiting for all of the adverstisements on the page to come up before actually getting to the data.
    I am making the Cumulus box upload now to a private web page, WUN and WCOP all at the same time along with the Homeseer Cumulus plugin polling the data from the Cumulus server and doing its own thing for my personal Homeseer server (variables, charting, et al).
    Seeing your own data is as simple as:
    http://www.findu.com/cgi-bin/wxpage.cgi?call=mynumber&last=36&radar=***
    Next pieces will include radio in the form of an APRS set up (geez takes me back as I used to get into ham radio in the 1960's).
  • Pete
    A side note for those using the Fine Offset weather station combo Cumulus application. The newest beta has a "maybe" fix for the USB disconnect issue which can be only fixed by removing the batteries and disconnecting the USB cable on the Fine Offset console.
    That said the Fine Offset in FL has had this issue twice this past year. This can be an issue if you let the application run and are not able to get to the console remotely.
    Also one of my favorite weather picture sites is coming back on line.
    http://twister.sbs.ohio-state.edu/
    http://twister.sbs.ohio-state.edu/sa...es-13/infrared
  • Pete
    I spent the last two days reviewing the Citizen Weather Observer Program (CWOP).
    http://info.aprs.net/index.php?title=Weather
    Most of this is done on a volunteer basis.
    Right now it appears to be neglected, documented in numerous ways but mostly disfunctional. Spot checking "active" CWOP weather stations show many (over 50%) not uploading any data at all. APRSWXNET also seems to be in disarray.
  • Pete
    Yes; I use NWS all of the time.
    I have three weather stations set up right now.
    Two of them have their own web sites using Comcast. Personallly my custom web comcast weather sites (personal pages) give me everything I need from just about any device out there...
    My preference though was to concurrently update two more sites with my weather data.
    These are the two Comcast sites. Two weather stations generate these via Cumulus; Homeseer Cumulus plugins takes their data every few minutes and uploads data to the following two Weatherunderground sites.
    Comcast -
    1 - http://lockport.golffan.us/
    2 - http://longboatkey.golffan.us/
    WeatherUnderground - log out of WUN and look to see how long the page takes to come up.
    1 - http://www.wunderground.com/weathers...p?ID=KILLOCKP1
    2 - http://www.wunderground.com/weathers...p?ID=KILLONGB2
  • Rupp
    It seems as though Weather Underground has put a lot of the little guys out of business. There's always the NWS and most all of their data is available in portable formats.
  • donstephens
    To get back to the original question ....
    Anyone using another Weather site?
  • Pete
    I have no need to Rupp.
  • Rupp
    Originally posted by Pete View Post
    I have been a member for years Rupp.
    I typically check my stuff out without signing in and right now its become a useless to those not signing in.
    Give it a try without signing in.
    I'm confused. If you are a member then why would you go to the site and not stay logged in?
  • Pete
    Status: No-Ads Paid Membership
    Expiration: 2013-12-08 02:03:40
    Signed Up: 2006-08-26 12:22:10
  • Rupp
    Join Weather Underground for only $10 a year and the adds are gone.
    http://wuhelp.wunderground.com/index...kbarticleid=14
