Ambient Weather Local Data Requirements
This is a sticky topic.
    HowTo: Convert a WS-2902 into at WS-1600-IP
    https://ambientweather.net/help/what...el-ws-1600-ip/
    ObserverIP Module
    https://www.ambientweather.com/amobserverip.html
    The ObserverIP Module received the sensor data from the PWS sensor array. However it does not have any indoor readings. These reading are provided by the WS-1000-BTH module.
    WS-1000-BTH
    https://www.ambientweather.com/amws1000bth.html
    Provides indoor temperature, humidity to the ObserverIP which also fill in the Abs/Rel pressure data points within the ObserverIP module
    WH31 Series (Add-on Sensors) Setup
    https://ambientweather.net/help/how-...e-wh31-series/
    Note 1:
    Without BOTH ObserverIP and WS-1000-BTH you will not have full data locally available through the AmbientWeather Plugin. This information is details in the Ambient Weather help article located here:
    Note 2:
    The WH31 Series "Add-On" Sensors DO NOT report locally. Their data is ONLY available through the AmbientWeather.Net interface.
    Originally posted by Simplex Technology View Post
    For a full local data package with Ambient Weather PWS setups the following are required.
    ObserverIP Module
    WS-1000-BTH
    Note:
    Without BOTH components you will not have full data locally available through the AmbientWeather Plugin. This information is details in the Ambient Weather help article located here:
    So I ordered a WS-1000-BTH and it's on the way. Finally we get to have our data 100% locally! Hurrah.
