Good Morning,
I purchased the Simplex plug-in and ordered a WS-2907A.
Everything installed properly and the plug-in setup all the devices. Got API from Ambientweather.net. everything worked as expected.
Now for the past several weeks the devices fail to update and ambientweather.net shows it is not getting the updates.
Router and network are fine the stations display module shows correct information. I can ping the device on the network and it responds as it should.
I have turned this thing every which way but loose
and can not get it to work correctly.
Some things I have done:
Removed station from ambientweather and resubmitted. acquired new API. Updated the plugin settings with new API and updated devices.
system starts to work properly.
Then stops. When it stops I can still see the weather station online on the local network and the remote sensors still report to the display.
I am lost and frustrated, any help will be welcome.
Ed
PS when it fails to update ambientweather the local device shows offline!
Ed
