Some devices not populated....
    This may well be user error, but....
    I am using trial v2.1.0.119 (non beta had fatal errors). All seems well, at this point, except Barometric Pressure (Abs), Barometric Pressure (Rel), Dew Point, Humidity Indoor, Rain Last, Temperature Feels Like, and Temperature Indoor have never updated.
    Barometric Pressure (Rel), Dew Point, Humidity Indoor, Temperature Feels Like, and Temperature Indoor are being reported locally and to Ambient. We've had no rain.
    I have the WS-2902A and ObserverIP.
    Any thoughts?
    Enabled Plug-Ins:
    Any thoughts?
    Did you also purchase the WS-1000-BTH to go with the ObserverIP module? The WS-1000BTH provides the Indoor temp/humidity and abs/rel Barametric information when running with the ObserverIP in Local mode. This is documented and here is the link.
    https://ambientweather.net/help/what...el-ws-1600-ip/
    Dew Point, Feels Like and Rain Last are only available through AmbientWeather.Net as they are computed values by their servers. To get those values you would run in Hybrid mode which is active if you have the ObserverIP configured but the Local Only NOT checked. This will pull information from the AmbientWeather.Net servers and the ObserverIP to give all information.
      No, I didn't know this was necessary, but I'll get one on order.... Ambient's description of this device is almost nonexistent and they don't seem to have posted a manual...
      These values appear in my Ambient webpage, but do not populate the devices. "Local Only Mode" is NOT checked in the PI.... so, as I understand it, I should be getting Dew Point, Feels Like, and Rain Last....
      Enabled Plug-Ins:
        Those should be populating. I'll have to check and re-verify they are not connected with the WS-1000BTH.....
          Perhaps related, perhaps not.... but I'm seeing these error in the log....
          Enabled Plug-Ins:
            The ObserverIP module is very fragile. Increase your polling to 30 seconds or greater (this error will still happen but less often) and then power off and on the OIP and restart the plugin. There's a known problem with the OIP where the web server crashes. This is a OIP hardware issue and Ambient Weather knows about it but won't do anything about it. Please send them complaints.
              OK, good! I changed the poll to 1 minute and haven't seen the error, since.....
              Enabled Plug-Ins:
                That's good.
                I know it's not great and some want the weather info faster. All I can suggest is send Ambient Weather emails saying you want local access and maybe they will put out a new upgraded OIP with more memory...
                  OK, let's return to the first post..... I have added the WS-1000-BTH, although I don't really know where to install it.
                  It has run over 12 hours and I am still not getting Dew Point, Rain Last, and Feels Like. Any idea how to get it to look for those parameters?
                  Enabled Plug-Ins:
                    Ok lets reset and get your basics again...
                    Plugin Version:
                    HS3 Info (Version Windows/Linux)
                    Are you using and ObserverIP Module? Is it setup? Is it setup to LOCAL ONLY?
                    Do you have the AmbientWeather.Net API key setup?
                    What PWS system is this again?
                      Sorry, I had all of that in my signature and forgot that all of that had disappeared with the forum "improvement."
                      Plugin Version:
                      I am using 2.1.0.119 (beta), as the non-beta version (2.1.0.34) gave fatal errors at start. Version 2.1.0.119 installed without incident.
                      Windows 10
                      I AM using ObserverIP. It is setup and reporting all values (missing and otherwise) to ambient. It is NOT set to LOCAL ONLY, but I had momentarily tried that option, while exploring the set up. I have also added the WS-1000BTH and if you can give me any information on what that item does, I'd appreciate it. Other than ability to order, the Ambient website says nothing about it.
                      I assume that it is set up correctly, as the weather station is currently reporting to WU, Ambient and PWS correctly.
                      I'm not exactly sure.... I started with the WS-2902A and the ObserverIP... so I guess the first answer would be that, but with the addition of the WS-1000BTH, I believe I can claim that it is a WS-1600. FWIW, my settings with WU describe the unit as a WS-2902. Do I need to change that?
                      [edit1]
                      OK..... maybe I just made brain contact.... I'm pretty positive I had used the wrong API key. So.... I went back to Ambient, generated a key, and inserted that into the PI. I'm waiting to see the result....
                      [/edit1]
                      [edit2]
                      At this point I have deleted all of the devices and recreated them..... still nothing reported from Ambient Weather.
                      [/edit2]
                      Enabled Plug-Ins:
                        If you updated the API Key and removed devices and there's no data then it's not connecting. Enable debug and post the logs.
                          To me, it looks like it isn't asking Ambient for those values..... all three are both checked and created. All three are in the .ini file and all three are marked true.
                          Small thing, but the error I received previously, caused by too frequent updates, was not chosen by me. Today, I noticed in the documentation that it should have been 1 minute. When I initially installed the plugin, I noted it was 7 seconds.... later, it had changed to 15 seconds.... all without user intervention. That issue was fixed by changing to one minute, which is fine by me... and DID fix the problem.
                          2018-12-08 10:22:02 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:22:02 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:22:02 AmbientWeather Debug Local Update Wind Direction: 27
                          2018-12-08 10:22:02 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:22:02 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:22:02 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:22:02 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:22:01 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:22:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:22:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Humidity Outdoor: 91
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Solar Radiation: 83.19
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Luminance: 10530
                          2018-12-08 10:22:01 AmbientWeather Debug Local Update Temperature Indoor: 69.4
                          2018-12-08 10:22:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:22:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:21:10 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:21:10 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:21:02 AmbientWeather Debug Local Update Luminance: 10158
                          2018-12-08 10:21:02 AmbientWeather Debug Local Update Temperature Indoor: 69.4
                          2018-12-08 10:21:02 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:21:02 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:21:02 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:21:02 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:21:02 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:21:02 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:21:02 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:21:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:21:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:21:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:21:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:21:01 AmbientWeather Debug Local Update Humidity Outdoor: 91
                          2018-12-08 10:21:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:21:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:21:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:21:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:21:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:21:01 AmbientWeather Debug Local Update Solar Radiation: 80.25
                          2018-12-08 10:21:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:21:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:20:02 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Humidity Outdoor: 91
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Solar Radiation: 79.27
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Luminance: 10034
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Temperature Indoor: 69.4
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:20:02 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:20:02 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:20:01 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:20:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:20:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:20:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:19:05 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:19:05 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:19:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Humidity Outdoor: 91
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Solar Radiation: 78.05
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Luminance: 9880
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Temperature Indoor: 69.3
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Wind Direction: 25
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Wind Gust: 2.5
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:19:01 AmbientWeather Debug Local Update Wind Speed: 0.9
                          2018-12-08 10:19:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:19:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:19:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:18:01 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:18:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:18:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Humidity Outdoor: 90
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Solar Radiation: 74.99
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Luminance: 9492
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Temperature Indoor: 69.3
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:18:01 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:18:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:18:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:17:03 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:17:03 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:17:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Humidity Outdoor: 89
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Solar Radiation: 74.14
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Luminance: 9385
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Temperature Indoor: 69.3
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Wind Gust: 2.5
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:17:01 AmbientWeather Debug Local Update Wind Speed: 0.2
                          2018-12-08 10:17:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:17:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:17:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:16:03 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:16:03 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:16:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Humidity Outdoor: 89
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Solar Radiation: 73.28
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Luminance: 9276
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Temperature Indoor: 69.3
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:16:01 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:16:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:16:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:16:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:15:03 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:15:03 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:15:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Humidity Outdoor: 90
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Solar Radiation: 74.14
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Luminance: 9385
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Temperature Indoor: 69.3
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:15:01 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:15:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:15:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:15:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:14:01 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:14:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:14:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Humidity Outdoor: 91
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Solar Radiation: 74.99
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Luminance: 9492
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Temperature Indoor: 69.1
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:14:01 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:14:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:14:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:13:01 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:13:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:13:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Humidity Outdoor: 91
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Solar Radiation: 71.93
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Luminance: 9105
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Temperature Indoor: 69.1
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Wind Gust: 2.5
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:13:01 AmbientWeather Debug Local Update Wind Speed: 0.2
                          2018-12-08 10:13:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:13:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:12:01 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:12:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:12:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Humidity Outdoor: 90
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Solar Radiation: 72.42
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Luminance: 9167
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Temperature Indoor: 69.1
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:12:01 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:12:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:12:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:11:06 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:11:06 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:11:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Humidity Outdoor: 90
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Solar Radiation: 72.42
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Luminance: 9167
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Temperature Indoor: 69.1
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:11:01 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:11:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:11:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:11:00 AmbientWeather Debug Connection Success.
                          2018-12-08 10:10:08 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:10:08 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:10:04 AmbientWeather Debug Connection Success.
                          2018-12-08 10:10:01 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Humidity Outdoor: 88
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Solar Radiation: 70.22
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Luminance: 8889
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Temperature Indoor: 69.3
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:10:01 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:10:01 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:10:00 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:08:56 AmbientWeather Debug ObserverIP Updating
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Barometric Pressure (Abs): 30.52
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Pressure (Rel): 31.67
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Humidity Indoor: 49
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Humidity Outdoor: 88
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Rain Daily: 0.02
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Rain Hourly: 0.00
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Rain Monthly: 1.22
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Yearly Rain Total: 1.22
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Rain Weekly: 0.21
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Solar Radiation: 69.36
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Luminance: 8780
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Temperature Indoor: 69.3
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Temperature Outdoor: 44.2
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update UV Index: 0
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Wind Direction: 26
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Wind Gust: 0.0
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Wind Gust Daily Max: 10.1
                          2018-12-08 10:08:56 AmbientWeather Debug Local Update Wind Speed: 0.0
                          2018-12-08 10:08:56 AmbientWeather Debug -------------------------------------------------
                          2018-12-08 10:08:56 AmbientWeather Debug AmbientWeather.Net Updating
                          2018-12-08 10:08:54 AmbientWeather Debug Connecting to AmbientWeather.Net...
                          2018-12-08 10:08:54 AmbientWeather Debug Connection Success.
                          Showing 1 to 350 of 350 entries
                          FirstPrevious1NextLast
                          Enabled Plug-Ins:
                            Some questions and your intentions.
                            I see a WS-2902 and ObserverIP enabled.
                            Do want want/care about Getting Local Data or getting All Data from AmbientWeather.Net?
                            I ask because currently you are ONLY getting LOCAL data. The connection to AmbientWeather.Net is NOT working. You will not get computed value sensors without AmbientWeather.Net data.
                              I don't know what I could have done wrong, except for the MAC address. The instructions were to "Input the weather station's MAC address." I did just that, should I have used the ObserverIP's MAC address instead or in addition to the display MAC address?
                              Yep. That was it. I added the ObserverIP to the dashboard and it's working.
                              Enabled Plug-Ins:
