Trying to start trial of this plugin to use with my new weather station But several hours after enabling plugin the message still says "INFO: Plugin start is pending." How do I get it to go?
Thanx
The version in the updater is unfortunately old. once I have a workstation I can work from again I'll go through updating things into the regular updater. Use the version in the Beta section as that is the latest and works the best.
