Cant bring up config page
    #31
    Welcome.
      #32
      Finally updated to the latest release... with my WS-1550-IP
      So how do you select the devices you wanted granularly? I have all the devices as above, but with the older plugin, I could create the devices I wanted and not all of them.
      Secondly, rain even show 33 mm of rain while live data from the OIP shows 1.3 mm. With old plugin, it was inn sync.
      Oh and config page seems to be missing logo
      File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\images\life360\simplextech-logo.png
      Is there documentation for this plugin?
      Robert
        #33
        Robert
        I'll have to get around to fixing the logo.
        Per the release posting all devices are created and available. I removed the options to select them as they are now auto discovered through the API. If you have a sensor it will be created and if you don't have that sensor then it wont' be created.
        For conversions from OIP to plugin to work correctly the OIP MUST be using US/Standard/Imperial units and then you select the unit conversion in the plugin page.
          #34
          Thanks... just a note, there's no life360 directory - though the file exists in the ambient weather directory. I just created the life360 directory and copied the file from the AmbientWeather directory.
          I guess you just hide the devices you don't want.
          All readings in the display are integers. How can we get more than zero decimal places as in the previous plugin? I'd like a couple of decimal places...
          Robert
            #35
            Robert
            It's been a while since I've been in the code but I'm taking the value as-is from the source and not doing any manipulations on it like before. What specific values are you looking at and from what source? OIP local or API?
            And yeah, you can just hide the devices you don't want to see.
              #36
              So I've taken the data both from the OIP and AmbientWeather. Doesn't seem to matter. All temperatures and rain related are integers only. This wasn't the case with v2.x. At least one decimal place would be helpful.
              One note, going to the AmbientWeather.net dashboard shows a double at least.
ID:	1332672Click image for larger version
                #37
                As you're running in metric I'm thinking it's probably related to my metric conversion rounding the value. I'll look into it.
                  #38
                  Yes I'm metric. It sure looks like it's getting rounded.
                  Thanks... much appreciated.
                  Robert
                    #39
                    Robert
                    Beta pushed to include 1 decimal value to match AmbientWeather.Net
                      #40
                      Wow... thank you very much! Didn't expect that so soon.
                      Robert
                        #41
                        Robert
                        Simple fix and I had a spare moment while setting up an unRaid system.
                          #42
                          Sorry, where can I find the beta?
