While this is not related to this excellent plug-in, I thought I would pick the collective brain trust. I have a WS-1001-WiFi station and an Observer IP. Here it the chain of events.
What am I missing?
- The weather station has worked flawlessly for years since I installed it
- The plug-in has been fine since it came out of beta. I started using the ObserverIP instead of WiFi through the WS-1001-WiFi display for posting to ambientweather.net and Weather Underground when I started using the plug-in
- I added 3 additional temperature/humidity sensors and they were also posting to ambientweather.net and being picked up by the plug-in
- About the end February, we started seeing wild fluctuations in reporting from the sensor array. Every minute the luminance would go to about 92,000 lux, then back to the correct reading. Temperature and other readings were acting similarly.
- I Replaced the batteries in the sensor and reinstalled it. Now we were getting readings for temperature and luminance that would go to 0 every minute, then back to their correct readings.
- I replaced the sensor array at the beginning of March. Everything seemed be be back to normal, but now the ObserverIP stopped posting to wunderground and ambientweather.net.
- I checked the firmware on the observerIP and found there was a newer version. I flashed the new firmware, still not reporting to either service.
- My network topology or configuration has not been changed much at all in a couple of years, definitely not at the time this started happening. It is a reliable and fast pure UniFi system.
- I replaced the ObserverIP. It still works fine locally with the plug-in, but will not post to either service.
- I have deleted and re-added the MAC addresses on ambientweather.net several times for each ObserverIP. I generated a new station ID and Key for Weather Underground. Nothing has changed.
- Through all of this the sensor array has communicated fine with the ObserverIP and the dedicated display. The plug-in gets data locally from the ObserverIP.
What am I missing?
