I try to apply HS3 license on HS4. it doesn't work. Do I need to buy it again?
HS3 plugin licenses couldn't be registered on HS4
Originally posted by sirmeili View PostThis plugin has not been tested on HS4 and currently I don't have plans on upgrading it just yet. I'm not sure why HST is allowing people to download plugins that aren't flagged for HS4 on HS4.-Rupp
Originally posted by Rupp View Post
As has been stated all along HS3 plugins are supposed to run in HS4.
I don't have time to support HS4 and l don't have time to validate that it "just works". Hence every time someone asks I state "I have not approved this plugin for HS4"
Rupp If they are all supposed to "just work", can you explain to me why I have this checkbox in the admin and why my plugins that are specifically not marked to run on HS4 are somehow marked for running on HS4?
Heck, I just noted the big notice right on the top (NOT ADDED BY ME) that says "Product Compatibility: HS3 Only"
I have the AmbientWeather PI and it does run under HS4 but sometimes you have to kick it after you reboot HS4. After reboot about half the time it shows status of INFO: Plugin start is pending. The only way I have found to get it to the correct status is to cycle the PI. Also at some point in one of the HS4 upgrades it duplicated all the devices, which I have not bothered to fix yet. I figure HS4 is at least 1 - 2 years from being Production at my house.
Originally posted by PFL View PostI try to apply HS3 license on HS4. it doesn't work. Do I need to buy it again?
Originally posted by sirmeili View PostRupp If they are all supposed to "just work", can you explain to me why I have this checkbox in the admin and why my plugins that are specifically not marked to run on HS4 are somehow marked for running on HS4?
-Rupp
