Cannot get initial install to work
    #16
    I'm still finding time to look into it. This week at work has been in prep for a big release on project I've spent the last 2 years of my life on. I will be on calls over the weekend so as long as things go smoothly (fingers crossed) I should be able to look at it this weekend.
    MeiAutomtion Home
      #17
      It seems like it might be okay now. I went through directory by directory deleting all files that said "Ambient Weather" and reinstalled. The X to uninstall does _not_ do a clean uninstall.
        #18
        Sorry, I've been working 13+ hour days all week with our release hypercare. I'm only now able to get to even check emails and forum posts.
        MeiAutomtion Home
          #19
          I got it work. I do have a feature request: the station has current conditions (clear / cloudy). Any way of exposing that as a "device"? Thanks.
          Sorry you're having to work so hard!
            #20
            I also have had problems getting the Plugin in Homeseer to work. Everything else is working, data is on the website, IP pings, ... please share with me what you did to get it to update the devices in Homeseer.
              #21
              Basically turned it off in the plug-in manager and removed the plug. Make sure you have not even a single device. Look under Device view, Floor filter for anything out of place.
              Shut down HS.
              Go through every HS folder and anything that said "AmbientWeather" I prefixed "xx" essentially deleting it.
              Restart HS.
              Reinstall plug-in. Be careful on the config since it doesn't report errors properly. For example, I originally did it without an API key since I didn't know what they were talking about (poor doc) and it accepted the config. Make sure, by the way, that the API is a user API key not a developer API key.
              Hope that helps.
                #22
                I have added this to my tracker.
                MeiAutomtion Home
                  #23
                  Let me know if tahl's suggestions don't help
                  MeiAutomtion Home
                    #24
                    Thanks for the help thus far. I will try your process today. Did you notice, when you were having problems, that the plugin continues to create duplicate fields? When I went back and looked at the devices after a few days, I had to delete about 500 fields. I haven't touched the create fields button since the install.
                      #25
                      So I followed the process being careful to delete any Ambient files in the folders and the plugin, deleted the 87 fields (there were dupes), restarted Homeseer, added the correct API. No luck. Here is the output from the log:
                      Date/Time Pri Type/Error Message/Source
                      Jul-10 12:50:00 PM AmbientWeather Debug {"error":"above-app-rate-limit"}
                      Jul-10 12:50:00 PM AmbientWeather Debug Polling Updating ObserverIP Data
                      Jul-10 12:50:00 PM AmbientWeather Debug Polling Updating AmbientWeather.Net Data
                      Jul-10 12:45:00 PM AmbientWeather Debug {"error":"above-app-rate-limit"}
                      Jul-10 12:45:00 PM AmbientWeather Debug Polling Updating ObserverIP Data
                      Jul-10 12:45:00 PM AmbientWeather Debug Polling Updating AmbientWeather.Net Data
                      Jul-10 12:40:00 PM AmbientWeather Debug {"error":"above-app-rate-limit"}
                      Jul-10 12:40:00 PM AmbientWeather Debug Polling Updating AmbientWeather.Net Data
                      Jul-10 12:40:00 PM AmbientWeather Debug Polling Updating ObserverIP Data
                      Jul-10 12:39:15 PM AmbientWeather Debug Created: 1526 Illuminance
                      Jul-10 12:39:15 PM AmbientWeather Debug Created Child: Illuminance
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Battery Outdoor
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1525 Battery Outdoor
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Rain Event
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1524 Rain Event
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Location
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1523 Location
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: TimeZone
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1522 TimeZone
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Last Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1521 Last Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Dew Point
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1520 Dew Point
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1519 Feels Like
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Feels Like
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Solar Radiation
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1518 Solar Radiation
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1517 UV Index
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: UV Index
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1516 Barometric Pressure (Abs)
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Barometric Pressure (Abs)
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Barometric Pressure (Rel)
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1515 Barometric Pressure (Rel)
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Total Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1514 Total Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Monthly Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1513 Monthly Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Weekly Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1512 Weekly Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Daily Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1511 Daily Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Hourly Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1510 Hourly Rain
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Humidity Indoor
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1509 Humidity Indoor
                      Jul-10 12:39:14 PM AmbientWeather Debug Created Child: Humidity Outdoor
                      Jul-10 12:39:14 PM AmbientWeather Debug Created: 1508 Humidity Outdoor
                      Jul-10 12:39:13 PM AmbientWeather Debug Created: 1507 Temperature Indoor
                      Jul-10 12:39:13 PM AmbientWeather Debug Created Child: Temperature Indoor
                      Jul-10 12:39:13 PM AmbientWeather Debug Created Child: Temperature Outdoor
                      Jul-10 12:39:13 PM AmbientWeather Debug Created: 1506 Temperature Outdoor
                      Jul-10 12:39:13 PM AmbientWeather Debug Created Child: Wind Gust Daily Max
                      Jul-10 12:39:13 PM AmbientWeather Debug Created: 1505 Wind Gust Daily Max
                      Jul-10 12:39:13 PM AmbientWeather Debug Created: 1504 Wind Gust
                      Jul-10 12:39:13 PM AmbientWeather Debug Created Child: Wind Speed
                      Jul-10 12:39:13 PM AmbientWeather Debug Created: 1503 Wind Speed
                      Jul-10 12:39:13 PM AmbientWeather Debug Created Child: Wind Direction
                      Jul-10 12:39:13 PM AmbientWeather Debug Created: 1502 Wind Direction
                      Jul-10 12:39:13 PM AmbientWeather Debug Created Root: E-Weather
                      Jul-10 12:39:13 PM AmbientWeather Debug [{"macAddress":"FC:F5:C4:98:67:6B","lastData":{"dateutc":1 594 399080000,"tempinf":78.4,"humidityin":50,"baromrelin":29.971 ,"baromabsin":29.835,"tempf":89.8,"battout":1,"humidity": 69, "winddir":250,"windspeedmph":6.5,"windgustmph":8.1,"maxd aily gust":10.3,"hourlyrainin":0,"eventrainin":0,"dailyrainin":0, "weeklyrainin":0.701,"monthlyrainin":0.701,"totalrainin" :0.7 01,"solarradiation":725.33,"uv":7,"feelsLike":104.66,"dewPo i nt":78.24,"feelsLikein":78.3,"dewPointin":58.2,"lastRain": "2 020-07-08T01:31:00.000Z","tz":"America/New_York","date":"2020-07-10T16:38:00.000Z"},"info":{"name":"E-Weather","coords":{"coords":{"lat":30.5364702,"lon":-84.3240873},"address":"5006 Brill Point, Tallahassee, FL 32312, USA","location":"Tallahassee","elevation":36.0179328918457, " geo":{"type":"Point","coordinates":[-84.3240873,30.5364702]}}}}]
                      I would appreciate any help.
                        #26
                        Good news that process worked!😉 Perhaps this could be included in the installation instructions or the uninstall code for the plugin.
                        Thanks for all the help!
                        Plugin is working great!
