Pressure scaling issue
    Reporting a plugin scaling issue.
    Ambient Weather Plugin V3.0.1.6
    Running on HS4 Pro V4.1.7.0
    I believe it is the same on HS3.
    The value does not display correctly (at all as it's overscale) when set to "hPa" display. It works OK in the "inHg" and "mmHg".
    In "hPa" I believe the raw value needs to be divided by 100 to get it back into range.
    Click image for larger version  Name:	Pressure.JPG Views:	0 Size:	27.8 KB ID:	1421707
    Click image for larger version  Name:	Settings.JPG Views:	0 Size:	37.8 KB ID:	1421708
    Click image for larger version  Name:	Scaling.JPG Views:	0 Size:	96.1 KB ID:	1421709
    I will check this out.
    MeiAutomtion Home
      Also found a similar problem with Wind Direction, no displayed value and the raw value on the status page shows 476.3. I suspect this is out by a factor of 10 but cannot confirm.
        Yes, I second the Wind direction problem. Numbers greater than 360 degrees... I'm not sure if it's out by a factor of 10 since once in a while it is within 360 and therefore reports a direction. I even tried to edit the status graphics numbers but they didn't stick and I couldn't find any workaround.
          Is there any hope of getting this wind direction issue to work correctly or should we just drop this request and move on? The plugin was released more than 2 years ago with issues reported but no fixes.
          Robert
