WS-2902C
    WS-2902C
    I'm planning to buy the Ambiant WS-2902C weather station, the newest model and use it with this plug-in. The description of the 2902C compared to the 2902A make me pretty confident it will be compatible. I'm also running HS4 on a Hometroller Zee. Just to double check I would appreciate any comments if there are potential issues.
    Many thanks
    Date/time=7/24/2021 3:21:29 PM EDT
    Version=HS4 ZEE S2/PI Edition 4.1.17.0 (Linux)
    MONO Version=Mono JIT compiler version 5.18.1.0 (tarball Fri Mar 15 21:12:47 UTC 2019)
    License=Registered
    Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json
    Uptime=3 Days 4 Hours 7 Minutes 27 Seconds
    Lan IP=192.168.0.32 (HomeTrollerZeeS2V5)
    Device Count=331
    Event Count=202
    Plugins Enabled=Z-Wave:,UltraM1G3:,Harmony Hub:,HS MyQ:
    Modules/Threads=80 Modules, 53 Threads
    Available Threads=399
    HomeSeer Memory Used=137 Mbytes
    Plugins Installed=Harmony Hub 4.0.12.0,HS MyQ 4.0.4.0,UltraM1G3 3.0.6922.16073,Z-Wave 3.0.4.0
    Many thanks
    License=Registered
    Device Count=331
    Event Count=202
    I going to guess it will be fine. I went from a WS-1001 WiFi to a WS-5000 last month. I called Ambient to verify that the new one was still compatible with the ObserverIP. When they confirmed that, I ordered and replaced with the WS-5000 and all is well. I’ve yet to install the lightning detector or the ground moisture sensor so I don’t know if the plug-in will pull them from ambientweather.net but everything else is reporting just fine.
