I saw on Cocoontech that Weather Channel's XML feed is going subscription (at $20/mo).What's going to happen to BLWeather?
Weather Channel XML feed going away
Dick
HS PRO 2.5.0.81, WinXP, IE8, Shuttle XS35V3, 2.13GHz, 4GB, 40GB SSD drive, AC-RF2, ADIOcelot, Message Server, TI103, SNEVL CID, pjcOutlook, MCSTemperature, Powertrigger, BLBackup, BLFloorplan, BLIcon, BLOccupied, BLRadar, BLRfid, BLLogMonitor, ACPUPSD, UltraECM, WeatherXML & Stipus' script connector. 500+ devices, 260+ events, 1-wire weather station + temp/humidity sensors & Oregon Scientific temp & humidity sensors & 2 Brultech ECM-1240sTags: None
I would need to find another source to get the information that is free. I am not going to pay for a weather service to test the plugin because I already own the WeatherLobby plugin for MainLobby that does all my weather for me.
If someone can find another weather source that provides the same information then let me know
Where does WeatherLobby get it's data from, Maybe you can utilize the same data feed?Marty
XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
Playing with HS3 a bit but it's just play at this point.
Bob, there's a discussion over on cocoontech about this very thing. There were at least one api, xml feed that were mentioned here.Marty
Hi Bob:
I thought I'd pose this question since the plug-in is no longer functioning due to changing weather feeds. I'm wondering if you have decided on a path back to functionality or a path to the trash?
I personally hope it can resurrected but I'll understand if it's end of life time. I and I'm sure the other users are wondering which way to go, hold and hope or start looking for something that can replace all the devices that were provided by BLWeather making it extremely easy to integrate into most any UI that was being used.Marty
