Display battery status in %
    Hello!
    I am using the script from here: https://forums.homeseer.com/forum/ho...ck?postcount=6
    I find this script quite handy because it shows the % on each battery in my system. However this isnt workin with the Netatmo3 batteries because they have value from 1-10000, instead of 1-100 like many other battery devices. Is there a way to divide the value by 100 to get the correct %value or is this something that has to be done from the creator of the plugin?
    This could maybe be a feature in the plugin that we could check if we wanted?
    Note: Since the script checks if battery > 100 it will automaticly print out error on Netatmo device batteries since they have a valuerange 100x normal batteries.(See pic below) Click image for larger version
    Zheep-
    Until the author updates the plugin, you will have to work around the issue. Here are a few ideas:
    1. Create a separate virtual device that will have the corrected value. Here is an excerpt from this post.
    Originally posted by mrhappy View Post
    If you create a new virtual device then set up a range value/status pair (end tab labelled status-graphics) that accepts a decimal value wide enough. Set the suffix to if you so wish, set it to status rather than both/control.
    Create an event and the trigger of the event is whenever your Neatatmo batteryvalue changes to anything, in the action add a single line scripting command which should be like this;
    &hs.setdevicevaluebyref(1234, (hs.devicevalueex(508) / 100), True)
    And see what it does, 1234 is the reference of your new virtual device and 508 is the reference of your Neatatmo input device.
    Note that I modified mrhappy's original quote to better suit your situation. I've highlighted my changes in purple italics. I have not tested this but it should at least get you started.
    2. You can modify the code of your script to handle the error differently...
    On lines 34-38 you have this IF statement:
       If dv.devValue(Nothing) > 100 Then ' if battery value is larger than 100(%), battery is invalid state
          myArray(UBound(myArray) - 1).devValue = "  ERROR"
       Else
          myArray(UBound(myArray) - 1).devValue = (dv.devValue(Nothing).ToString & "%").PadLeft(7)
       End If
    If you wrap that with an IF statement looking for your device reference ID, you can do the math there...
       If [ref id is 508]
          [save value as original value/100]
       Else
          Else
          End If
       End If
    Note... I can't be sure without testing what the correct code lines would be... but your basis is already in the original code. mwaite would be a good person to ask how to modify his code, but maybe this will get you going in the right direction:
       If dv.Ref(Nothing).ToString = 508
          myArray(UBound(myArray) - 1).devValue = ((dv.devValue(Nothing) / 100).ToString & "%").PadLeft(7)
       Else
          Else
          End If
       End If
    The biggest thing I'm not sure about is doing math with the .ToString function. I hope some of this helps...
      B1Trash
      Thanks for your quick reply!
      What i have done is almost what u said in suggestion 1. But instead of creating a virtual device, i just updated the value on the device itself.
      The reason for not using a virtual device is that i would have to change so many things to make it fit into the script mentioned.
      However by using this code &hs.setdevicevaluebyref(508, (hs.devicevalueex(508) / 100), True) in a script i was able to change the value until next change. To avoid looping(which happend when i first tried it) i have added a new then setting and added a delay for when it can run again. Look on the pic under for my event setup.
      This is how it looks in the advanced tab now, previously it was 6144. So the only thing left to do now is create a new statusgraphics acordingly to the changes, i.e Range value from 0-100 and graphics that correspond.
      When i think about it now it probably should work with only the cannot re-run for timer set to 10 secs. This should be within the limit of the refresh rate of the sensor aswell which by the plug-ins standards cant be less than 5 minutes.
        I never thought of resetting its own value. That's brilliant!
          That's a great function; should be built-into HS.
          But, I coped the file into the HS3 scripts folder (running HS4) and added it to a manually executed event (for testing). I did edit the Email TO address.
          BUT, when I execute the event I get:
          HomeSeer Event Error Event (Low Battery, Send Email) action Run Script could not be completed - action does not have a valid script file or immediate command"
          I have a feeling I haven't done something fundamental correctly -- any ideas?
            Jeff492
            If it is the script from the post i mentioned that is not working, you should probably try to ask in that thread.
            I currently dont have anything from HS running, as the reason why i used HS was for my bachelor thesis. So sadly I can't help you with this problem right now..
            I have no idea if anything major has changed from HS3 to HS4, and if that is the reason why it doesnt work.
            I hope you can figure it out, so you get the script up and running, because it is indeed a great function to have!
