Temperature Problem
    Temperature Problem
    I've got a problem when I have HS speak the current temperature. When it speaks, it says something like, "The current temperature is 81.27 degrees". What would I need to do to remove the decimal and have it just say 81 degrees? Love the plug-in by the way. I bought the Netatmo equipment just because I liked this plugin and the features it brings to HS.
    Thanks in advance...
    Jerry
    Bump
      Courious... Is this plugin still being supported?
        When you're speaking the temperature, change the value to an integer to remove the decimal point. Post your speak command you're using here and I'll reply on how to modify it so it doesn't speak the decimal point.
