Is it possible for you to implement the temperature icons from HS3 to be used with netatmo? It would be better i think to have the same icons for this. Instead of going in and change them ourself?
I could if you want try make new icons for humidity, co2 and pressure to start with, in the same style as HS3 new icons?
For now it would be good if one could have temperature and battery from the new icons in HS3.
Thank you!
Thank you!
