I found a script in here and have modified it a bit to send the current weather alert to a device code that I use for other things as well. It's worked great for a month or more but todays alert came in all in uppercase letters. Usually the alert is not sent that way but today it was. The line I use to send the output to the device is
Is there a way to convert it to lowercase before sending it to the device? Also, would that effect anything if the alert was already in lowercase?
PHP Code:
hs.SetDeviceString("Z90",String.Format("{0}", strAlertType, strAlertTitle),True)
