Trigger Action
    Trigger Action
    I just started getting this error a few days ago. I though since I had not changed anything it might go away, but it hasnt. Any ideas on what this error is doing? Thank you in advance for any help. I have no idea for sure when it happened, I just noticed it the last couple of days and we have had no warnings.
    danielbo
    Hello danielbo. Please try to open any events assoicated with UltraWeatherBug and re-save them to see if it resolves the issue you reported.
    Ultrajones
      Thanks, I think I have maybe more problems.
      Hi, I had gone back and saved each events, I will watch it, but after I saved each event I got these errors.
      It look like there might be more issues. What do you think?
      danielbo
        I did notice, that it is happening on the hour, and I have the weather read out the server speakers every hour, well one minute after. But I am getting the weather spoken without a problem. So I dont know why I would be getting a error. That seems to be running fine. I will listen closer tomorrow when it starts again, It is set to shut down for the rest of tonight. But that does narrow down where the problem is. I had thought it was where I had it set so the attic fans would kick on and off according to the outdoor temperature. It had been shut off during the winter and I have just recently turn it back on, and it seem about that time the error messages started. So I thought that was the problem, but I now notice that it is happening just on the hour, so that cant be the problem with the attic fans.
        danielbo
          I believe I may have introduced this error when I added an option to allow users to specify the speaker instance in the HomeSeer event action. Simply re-adding the aciton will resolve the isuse. Sorry for the inconvienience.
          Ultrajones
            I just upload UltraWeatherBug HSPI version 1.0.4536.15151 which fixes the issue you reported.
              UJ, I just wanted you to know I updated this yesterday and was receiving the same errors as above, I was able to fix it with the suggestions in this thread but I thought you might want to know that after an update the errors are still being introduced.
              Marty
              XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
              Playing with HS3 a bit but it's just play at this point.
