installed but cant see it
    i installed this plug in , rebooted HSpro, it came up and installed, said it was installed successfully, but i dont see it anywhere, not in the logs, not on the setup screen.
    any idea what im doing wrong?
    detail of setup in profile. Link to videos of my projects there as well. Over 300 scripts running every min and counting
    Do you have it enabled on the Interfaces page?
    HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
    Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
    Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
    Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
      For me it's under the tab marked plug-ins
      Marty
      XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
      Playing with HS3 a bit but it's just play at this point.
        It's not even showing up on the interfaces page
          Ouch, maybe a reinstall? something strange must have happened during the install. You should be able to go back to the updater page and just select it again.
          Marty
            I did, twice, says its successfully installed. But nothing
              Are there any errors in the HomeSeer log file when HomeSeer is restarted?
              -Rupp
                I think i see what the problem i s. i have HS PRO and it TRYING to install itself in a folder called homeseer 2 , i guess its not following the root homeseer install directory, just assuming that it should go into homeseer 2
                  ok, manually copying each file over and adding the settings to the main hs settings.ini file seems to have fixed it. bad installation programming there on the designers part
                    Originally posted by collegeboyslive View Post
                    OK, manually copying each file over and adding the settings to the main HS settings.ini file seems to have fixed it. bad installation programming there on the designers part
                    Did you uninstall HomeSeer 2 prior to installing HomeSeer Pro? If not then there are registry entries pointing to the old install and it's not the fault of the developer.
                    -Rupp
                      yes, this never has sh2 on it, it was a totally fresh install including windows, fresh from the ground up
                        The UltraWeatherBug HSPI uses the installer package provided by HomeSeer. If your HomeSeer instance didn't find the proper install directory, then open a ticket with HomeSeer so they can determine what changes are required to fix this issue. Thank you.
                        Ultrajones
