Install error - Solved!
  • Install error - Solved!
    I just installed the plugin through the updater but when I click on the config button I get the following error on the page:
    System.MissingMemberException: Public member 'WEBUserRolesAuthorized' on type 'MarshalByRefObject' not found. at Microsoft.VisualBasic.CompilerServices.Symbols.Container.Get Members(String& MemberName, Boolean ReportErrors) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGe t(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at ASP.hspi_ultraweatherbug_hspi_ultraweatherbug_aspx.Page_Load (Object sender, EventArgs e)
    I'm running the latest version of HS on a Windows XP machine.
    Uninstalled plugin, applied all windows updates and then re-installed. Still getting the same error when I try to setup???
    Any suggestions??
      What version of HS are you running?
      -Rupp
        I finally got it working. I was running HS as a service. Once I changed that, it started working again!!
