After a fatal crash I got up and going with new install (fortunate I had back), I have download all my plugin with no issues,but I having problems tryin to down load ultraweatherbug,. It's shows on the log that it has been installed, but when I chk in my Interface screen it's not there. Tried several time but it does not show.
Is the updater working?
I think when you installed the speaker client update, it also updated the default location of your HomeSeer directory. When you ran the installer, it picked up this value and may have installed it in the new location. Can you perform a search to determine where HSPI_ULTRAWEATHERBUG.dll is installed on your system?
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by Ultrajones View PostI think when you installed the speaker client update, it also updated the default location of your HomeSeer directory. When you ran the installer, it picked up this value and may have installed it in the new location. Can you perform a search to determine where HSPI_ULTRAWEATHERBUG.dll is installed on your system?
UltrajonesHector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Based on what you are telling me, the plug-in is not installing correctly. Please uninstall it, then manually remove:
{homeseer root}/html/hspi_ultraweatherbug
{homeseer root}/html/images/hspi_ultraweatherbug
{homeseer root}/hspi_ultraweatherbug.*
Then reinstall it from the HomeSeer updater.
Originally posted by Ultrajones View PostBased on what you are telling me, the plug-in is not installing correctly. Please uninstall it, then manually remove:
UltrajonesHector
Win.2003 OS, HS3
Ok, found it, uninstall ,removed files, reinstalled so far looking good. Thks you Ultra, I will keep a eye on it.Hector
Win.2003 OS, HS3
