I tested this app last year with squeezebox and then never proceeded with squeezebox. I wanted to do the same as I am planning on going with Sonos systems. Is there a way I can try the app again?
BTW I own an UltraWB license.
It is so solid I forget it is running.
If you can get on the Weatherbug website and find local stations you are happy with you might as well just get the plugin.
