WeatherBug Pulse API - FINAL NOTICE
  • #16
    Yes, both versions will be converted. HS3 is first.
    • #17
      Originally posted by Ultrajones View Post
      I just received confirmation from WeatherBug that each user can sign up for their own free PRO API key that includes 15,000 queries per month. I also have an extra month to make the plug-in conversion. At this point, it seems this crisis has been averted.
      Ultrajones
      Yea! Thank you for all of your effort. It is much appreciated. I really like your interface work (I own 3) and was really hoping to stick with UltraWeatherBug.
      Randy Prade
      Aurora, CO
      Prades.net
      • #18
        So, it looks like it stopped working (for me anyway) this afternoon.
        How long before there is a fix for HS2?
        • #19
          I have been working on it and have figured out the JSON queries. I ended up taking next week off to work on it. It is almost a complete re-write as WeatherBug abandoned the XML feeds. So, should be some time next week
          Ultrajones
          • #20
            Yup, mine stopped updating at 3:06 MDT (HS3).
            I understand the difficulty - no rush.
            Randy Prade
            Aurora, CO
            Prades.net
            • #21
              I am a good 16 hours into the conversion. Here is a screenshot of the progress ...
              • #22
                Yea! I'm anxious to get it back.
                Randy Prade
                Aurora, CO
                Prades.net
                • #23
                  More coffee!!!
                  If it ain't broke, don't fix it!
                  • #24
                    Waiting patiently.... :-)
                    -Tim
                    HSPro - 3.XXX - Dell mini W7 x32
                    Way2 Call
                    Elk M1 Gold
                    UPB HAI switches
                    HAI RC2000 Thermostat
                    • #25
                      Ultrajones
                      Where do we do this?
                      ________________________
                      Dell Zino HD - HSPRo 2.x
                      HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
                      2 x Brultech ECM1240 with UltraECM
                      USB UIRT
                      Cooper Aspire Z-Wave Switches
                      WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
                      HM ST812-2 Flood Sensor
                      HSM100 - Motion Detector with Light and Temperature
                      2GIG Thermostat
                      BLDSC - Alarm Plug-in
                      BLUPS
                      UltraLog (SQL2008)
                      Jon00 Plugins
                      Host XR3 BT and Jon00 BT Proximity
                      Global Cache IP2IR
                      Foscam FI8918W
                      • #26
                        http://api-portal.earthnetworks.com/user/register
                        • #27
                          More Screenshots ...
                          • #28
                            Ultra, I just registered, what info do we need to start using ultraweatherbug? Also will you be adding to the plug the "Spark" feature? This will be great if you can get a lightning warning if it occurs....
                            Hector
                            Win.2003 OS, HS3
                            MyTrigger,ACRF2,W800,Zwave
                            AP800,Honeywell Stat
                            • #29
                              API
                              Me too, but how use it to the plugin now?
                              I use HSpro 2.5
                              • #30
                                The new plug-in was just posted. Please review the documentation on how to register for the Pulse API key. I also recommend you delete and re-create the devices after the plug-in is installed and re-define your weather stations.
                                You'll also need to enable/disable the plug-in after entering your API key.
                                Ultrajones
