Is this for HS2 and HS3?
WeatherBug Pulse API - FINAL NOTICE
I installed the new version but could not find a section in the documentation the type of key to create. I tried to use the keys for a basic free package "Spark Lightning" but when I try to query for stations, I get the following in the log file (debug enabled). Any suggestion?
PHP Code:4/12/2014 4:56:05 PM...Debug~~!~~https://thepulseapi.earthnetworks.com/getLocations/data/locations/v2/location?SearchString=...... {delete rest of query}
4/12/2014 4:56:05 PM...Error~~!~~System.Net.WebException
4/12/2014 4:56:05 PM...Error~~!~~System.Net.WebException: The remote server returned an error: (500) Internal Server Error.
at System.Net.HttpWebRequest.GetResponse()
at HSPI_ULTRAWEATHERBUG3.hspi_weatherbug_api.GetLocations(String searchString)
Originally posted by pcp View PostI installed the new version but could not find a section in the documentation the type of key to create. I tried to use the keys for a basic free package "Spark Lightning" but when I try to query for stations, I get the following in the log file (debug enabled). Any suggestion?
If the UltraWeatherBug3 HSPI setup screen is being displayed, then your API key you entered is not valid. Can you double check to make sure it is a *Pulse API PRO* key and you have entered both the Consumer Key and Secret Key into the text boxes provided?
Regards,
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Originally posted by rprade View PostGo to "Plug-ins" and you will get a drop down that includes UltraWeatherbug3 and a flyout. Click on the flyout and you will get the configuration screen.
So there is no setup screen for UltraWeatherBug where i can put in my API
I cannot duplicate this issue. I tried on multiple different browsers and no issues whatsoever viewing the Status, Options and Speech we pages when no API key is present.
Please clear your browser's cache and try again. If it continues to fail, please use IE.
Regards,
