errors in stting up weatherbug for HS3
  • errors in stting up weatherbug for HS3
    I satrted setting up weatherbug for HS3 today and I entered the API info but I get alot of errors in the Hs log not sure what went wrong.
    Here are the errors can some one help
    May-20 4:27:44 PM 1 Error System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetAlertsWeather(String strStationNumber)
    GetAlertsWeather
    GetAlertsWeather
    May-20 4:27:43 PM 1 Error System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetForecastWeather(String strStationNumber)
    GetForecastWeather
    May-20 4:27:43 PM 1 Error System.InvalidCastException: Conversion from string "" to type 'Double' is not valid. ---{0x3E} System.FormatException: Input string was not in a correct format. at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDoub le(String Value, NumberFormatInfo NumberFormat) at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble( String Value, NumberFormatInfo NumberFormat) --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble( String Value, NumberFormatInfo NumberFormat) at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetLiveWeather(String strStationNumber)
    GetLiveWeather
    GetLiveWeather
    GetForecastWeather
    May-20 4:27:43 PM 1 Error System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetAlertsWeather(String strStationNumber)
    GetAlertsWeather
    GetAlertsWeather
    May-20 4:27:42 PM 1 Error System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetForecastWeather(String strStationNumber)
    GetForecastWeather
    GetForecastWeather
    May-20 4:27:42 PM 1 Error System.InvalidCastException: Conversion from string "" to type 'Double' is not valid. ---{0x3E} System.FormatException: Input string was not in a correct format. at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDoub le(String Value, NumberFormatInfo NumberFormat) at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble( String Value, NumberFormatInfo NumberFormat) --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble( String Value, NumberFormatInfo NumberFormat) at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetLiveWeather(String strStationNumber)
    Cheers Ken
    HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
    Does Status > WeatherBug Pulse API > Valid Key indicate true or false?
      It is True
        I have a similar issue. not sure if it's the same or not. In Startup log, I get:
        6/1/2014 10:27:08 AM ~!~Plug-In~!~Finished initializing plug-in UltraWeatherBug3
        6/1/2014 10:27:08 AM ~!~Info~!~Plugin UltraSMTP3 has connected. IP:127.0.0.1:51165
        6/1/2014 10:27:08 AM ~!~Error~!~System.NullReferenceException
        6/1/2014 10:27:08 AM ~!~Error~!~System.NullReferenceException: Object reference not set to an instance of an object.   at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetAlertsWeather(String strStationNumber)
        6/1/2014 10:27:08 AM ~!~Error~!~System.InvalidCastException
        6/1/2014 10:27:08 AM ~!~Error~!~System.InvalidCastException: Conversion from string "" to type 'Double' is not valid. ---> System.FormatException: Input string was not in a correct format.   at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)   at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)   --- End of inner exception stack trace ---   at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)   at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetLiveWeather(String strStationNumber)
        6/1/2014 10:27:08 AM ~!~Error~!~System.NullReferenceException: Object reference not set to an instance of an object.   at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetForecastWeather(String strStationNumber)
        6/1/2014 10:27:09 AM ~!~Error~!~System.NullReferenceException
        6/1/2014 10:27:09 AM ~!~Error~!~System.NullReferenceException: Object reference not set to an instance of an object.   at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetForecastWeather(String strStationNumber)
        6/1/2014 10:27:09 AM ~!~Error~!~System.InvalidCastException
        6/1/2014 10:27:09 AM ~!~Error~!~System.InvalidCastException: Conversion from string "" to type 'Double' is not valid. ---> System.FormatException: Input string was not in a correct format.   at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)   at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)   --- End of inner exception stack trace ---   at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)   at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetLiveWeather(String strStationNumber)
        6/1/2014 10:27:12 AM ~!~Plug-In~!~Finished initializing plug-in UltraSMTP3
        Plus, here is a screenshot showing failures:
          Please log into the WeatherBug site to confirm your "Active Plans" is "Pro Package FREE" (see screenshot).
          Ultrajones
            yes, that is set just like your screen shot. I enabled debug
            Jun-14 11:06:22 AM	 1	 Error	 System.InvalidCastException: Conversion from string "" to type 'Double' is not valid. ---{0x3E} System.FormatException: Input string was not in a correct format. at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat) at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat) --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat) at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetLiveWeather(String strStationNumber)
             	  	  	     GetLiveWeather
            Jun-14 11:06:22 AM	 1	 Error	 System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetForecastWeather(String strStationNumber)
             	  	  	     GetForecastWeather
             	  	  	     GetLiveWeather
             	  	  	     GetForecastWeather
             	  	  	     GetForecastWeather
             	  	  	     GetForecastWeather
            Jun-14 11:06:22 AM	 1	 Error	 System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetAlertsWeather(String strStationNumber)
             	  	  	     GetAlertsWeather
             	  	  	     GetAlertsWeather
             	  	  	     GetLiveWeather
             	  	  	     GetLiveWeather
            Jun-14 11:06:21 AM	  	 Web Server	 SSL Web Server started on port 8068
             	  	  	     (System)_14-Jun-2014 11:06:21.8466_SSL Server Listener
            Jun-14 11:06:21 AM	 1	 Error	 System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetAlertsWeather(String strStationNumber)
             	  	  	     GetAlertsWeather
             	  	  	     GetAlertsWeather
               	  	  	     GetLiveWeather
               	  	  	     GetForecastWeather
               	  	  	     GetLiveWeather
               	  	  	     GetForecastWeather
               	  	  	     GetForecastWeather
               	  	  	     GetForecastWeather
               	  	  	     GetAlertsWeather
               	  	  	     GetAlertsWeather
               	  	  	     GetLiveWeather
               	  	  	     GetLiveWeather
               	  	  	     GetAlertsWeather
               	  	  	     GetAlertsWeather
              Please send your WeatherBug INI file to ultrajones@hotmail.com please.
                Hi Ultra, I deleted the plugin, Deleted ultra weather in Data and Config and started from scratch and it works fine now.
                  Can't add stations in UltraWeatherBug3
                  My WeatherBug pulse says True
                  I have not gotten any errors, but I can't set up any stations.
                  I have used UltraWeatherBug for many years with HS2 with no problems.
                  Any Ideas?
