I turned on debug and captured the url and tested it. Th log is showing error 403
I got this using the url from the log
<error><messages><message>Exceeded developer limit configuration - </message><message>Is Developer Suspended - true </message></messages></error>
Forecast is working ok.
It has been working fine for many months but a few days ago I received 15 emails on the same day all with the same time of 5:35AM. The message said
"You have exceeded the limit for your plan called for. Your calls are blocked till $expiry date. Please upgrade your plan or wait till your limit is replenished in order to continue to access this product."
Very strange. I was not home at the time this happened.
The HS log looks normal except for this problem with UltraWeatherBug which shows in the log at 5:33AM. . The HS log on the day it happened at 5:33 AM I see that there were 10 queries of the earthnetworks.com web site within 3 seconds then several more over the next 2 seconds which all returned the 403 error. After that when the query is made every 15 minutes the error 403 is returned.
How can I restore things? Or, do I just have to wait - for how long?
