Hi - I've not been able to pull in any data, other than for station 1. I decided to change one of them (station 4) to the same site as station 1, and it still does not populate station 4. What am I doing wrong?
WeatherBug silently implemented a 1 query per second query limit.
{ "statusCode": 429, "message": "Rate limit is exceeded. Try again in 1 seconds." }
Please download UltraWeahterBug3 HSPI version 3.0.5677.15464 and let me know if that fixes the issue you reported.
Please Note: If you are going to define more than 1 station, you'll need to increase the update frequency to +15 minutes per station. So, if you have 3 stations, you're update should be set to every 45 minutes.
