No Stations Will Populate
  • No Stations Will Populate
    Just installed and started working on this. I've gotten a valid API key and everything appears to be working correctly but I can't seem to get any weather stations to populate. I've tried multiple local zip codes, town names, etc to no avail. Have I missed a step somewhere? The API key reads Valid but the Success rate is zero. I assume this is because there isn't a station defined currently.
    Ver. 3.0.5712.31691
    If the success rate is 0, then means your key is being refused by WeatherBug. Can you enable debug to see if anything of value is written to the logs?
    Ultrajones
      Yep. I'll do that and report back.
        error in log
        This is what i get in the log when i try to set a station.
        Nov-19 10:58:36 AM 1 Error System.Net.WebException: The remote server returned an error: (401) Unauthorized. at System.Net.HttpWebRequest.GetResponse() at HSPI_ULTRAWEATHERBUG3.hspi_weatherbug_api.GetLocations(Strin g searchString)
          Are you using the credentials provided by WeatherBug that are associated with their new $20 per month plan?
            Yep. I signed up, paid the fee and did a copy/paste of the key just like instructions. I will double check and make sure the key is correct.
              There must have been some kind of screw-up on my part. I checked and found that the charge for the API key never hit my account. Don't know where i got that API key but that was the problem. I signed up again and now it seems to be working. sorry to have wasted your time! Thanks.
                No worries! I am glad it is working
