HS3 - Restarting HS3 erases Low Temp
  • HS3 - Restarting HS3 erases Low Temp
    Low Temp device is populated with correct temp in the morning. If HS3 is restarted at any time during the day, Low Temp device erases to 0 degrees.
    Tried with using both CSV and dBase, and CSV only processing.
    Attached are dbase.csv, data.csv, and data2.csv (changed to .txt) files for upload
    1.) First ENABLE debug and restart.
    2.) After low temp failure copy and post the VWS.log file located in HS-Directory/Logs
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
      Here is the contents of VWS.log. I have confirmed that the Low Temp devise shows 0 degrees and was updated at 3:39:08pm
      Thanks for the help.
      12/30/2013 3:39:06 PM ~***************************************
      12/30/2013 3:39:06 PM ~VWS Debug Enabled.
      12/30/2013 3:39:06 PM ~VWS Debug Logging toC:\Program Files (x86)\HomeSeer HS3\Logs\VWS.log.
      12/30/2013 3:39:06 PM ~VWS HS-Version: 3.0.0.54
      12/30/2013 3:39:06 PM ~VWS Plug-In Version: 3.0.0.7
      12/30/2013 3:39:06 PM ~VWS Plug-In Server IP Address: 127.0.0.1
      12/30/2013 3:39:06 PM ~VWS* gDayLast: 30
      12/30/2013 3:39:06 PM ~VWS* gMonthLast: 12
      12/30/2013 3:39:06 PM ~VWS* gHighTemp: 54.3
      12/30/2013 3:39:06 PM ~VWS* gLowTemp: 40.9
      12/30/2013 3:39:06 PM ~VWS* gCSVPollInterval: 5
      12/30/2013 3:39:06 PM ~VWS* gDBasePollInterval: 2
      12/30/2013 3:39:06 PM ~VWS* gWarningInterval: 1
      12/30/2013 3:39:06 PM ~VWS* gSpeakCount: 0
      12/30/2013 3:39:06 PM ~VWS* gCSVPath: c:\vws\data\
      12/30/2013 3:39:06 PM ~VWS* gDBasePath: c:\vws\data\
      12/30/2013 3:39:06 PM ~VWS* gWarningPath: c:\vws\data\warning\
      12/30/2013 3:39:06 PM ~VWS* gPreSpeakStr:
      12/30/2013 3:39:06 PM ~VWS* gSpeak: False
      12/30/2013 3:39:06 PM ~VWS* gMetric: False
      12/30/2013 3:39:06 PM ~VWS* gScaleValues: True
      12/30/2013 3:39:06 PM ~VWS* gReadCSV: True
      12/30/2013 3:39:06 PM ~VWS* gReadDBase: False
      12/30/2013 3:39:06 PM ~VWS* gReadBoth: False
      12/30/2013 3:39:06 PM ~VWS* gLastWarningTime: 1/1/0001 12:00:00 AM
      12/30/2013 3:39:06 PM ~VWS* gNumTimesToWarn: 1
      12/30/2013 3:39:06 PM ~VWS* gMinutesBetweenWarn: 15
      12/30/2013 3:39:06 PM ~VWS* gNightStopTime: 22
      12/30/2013 3:39:06 PM ~VWS* gMorningBeginTime: 9
      12/30/2013 3:39:06 PM ~VWS* gUseWarning: True
      12/30/2013 3:39:06 PM ~Entering DeleteMyDevices()....
      12/30/2013 3:39:07 PM ~Entering...InitDevices().
      12/30/2013 3:39:07 PM ~Entering CreateDevices()....
      12/30/2013 3:39:08 PM ~Entering RegisterWebPage()....
      12/30/2013 3:39:08 PM ~Entering RegisterHelpPage()....
      12/30/2013 3:39:08 PM ~Loading Dictionary
      12/30/2013 3:39:08 PM ~ParseLine()--- String: mph=miles per hour using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: kph=kilometers per hour using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: ft=feet using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: pm=P M using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: am=A M using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: est=eastern standard time using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: cst=central standard time using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: mst=mountain standard time using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: pst=pacific standard time using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: dst=daylight savings time using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: n=north using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: ne=north east using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: ene=east north east using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: e=east using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: ese=east south east using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: se=south east using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: s=south using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: sw=south west using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: wsw=west south west using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: w=west using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: wnw=west north west using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: nw=north west using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: mon=monday using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: tue=tuesday using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: wed=wednesday using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: thu=thursday using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: fri=friday using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: sat=saturday using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: sun=sunday using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: jan=january using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: feb=febuary using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: mar=march using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: apr=april using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: jun=june using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: jul=july using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: aug=august using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: sep=september using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: oct=october using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: nov=november using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: dec=december using delimiter: =
      12/30/2013 3:39:08 PM ~ParseLine()--- String: wind=wend using delimiter: =
        Please send me the complete VWS.log not just a snippet. There are many functions and debug statements that lead up to the device updates and need to see them.
        The easiest way is to attach the log file here.
        -Larry
        Plugins:
        Hardware:
          That was the entire logfile. I updated the VWS and restarted again with debugging.. Here's the VWS log attached
            Great thx, I will start diagnosing today.
            -Larry
            Plugins:
            Hardware:
              New version sent to the updater.
              -Larry
              Plugins:
              Hardware:
                Updated the plugin, still lose Low Temp when restarting HS3. Attached is logfile. Is there any special configuration necessary in Virtual Weather Station that I may have missed that could be causing it. This was a fresh install of HS3 and VWS, and the only thing I did from out of the box was enable CSV export if I recall correctly.
