For some reason I get a double row of buttons when I select Forecast under User, which is weatherXML?pg=4. All the other User pages come out correctly with a single row. Is this a bug or do I have a setting incorrect?
Double row of buttons
Look at the bottom of the page. Is there a row of buttons at the bottom of the page. If not, then I suspect there is an error that is not letting the page build completely. Go to the settings page and set logging level to Debug. Then go back to the forecast page. After that check the log to see if there are any errors.
Make sure you change the logging level back to errors or you will fill your log with debug entries.--
Jeff Farmer
HS 3, HSPhone
