Error in Event Log When PI Tries to Download Conditions
    Started happening recently. Whenever my PI (3.0.0.63) tries to download Conditions from Weather Underground I get the following error;
    Image file does not exist, returning blank image: C:\Program Files\HomeSeer HS3\html\0
    Any ideas what it's trying to do and how I can fix it?
    I enabled debug logging and here's what's causing it. Newest at top.
    Jun-02 9:10:01 AM weatherXML Set Javascript Condition Image
    Jun-02 9:10:00 AM Warning Image file does not exist, returning blank image: C:\Program Files\HomeSeer HS3\html\0
    Jun-02 9:10:00 AM weatherXML Use File: C:\Program Files\HomeSeer HS3\html/images/weatherXML/condition/cloudy_0.gif
    Jun-02 9:10:00 AM weatherXML Use image: /images/weatherXML/condition/cloudy_0.gif for HSTouch
    Jun-02 9:10:00 AM weatherXML Check for refID: 4456
    Jun-02 9:10:00 AM weatherXML Check for replace with
    Jun-02 9:10:00 AM weatherXML Check for refID: 4455
    Jun-02 9:10:00 AM weatherXML Save to: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\cloudy_0.gif
    Jun-02 9:10:00 AM weatherXML Downloading the weatherXML: curcond.jpg file at http://icons.wxug.com/i/c/j/cloudy.gif.
    Jun-02 9:10:00 AM weatherXML Replacement URL: http://icons.wxug.com/i/c/j/cloudy.gif
    Jun-02 9:10:00 AM weatherXML Save condition image to: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\curcond1.jpg
    Jun-02 9:10:00 AM weatherXML Download image: http://icons.wxug.com/i/c/j/cloudy.gif
    Jun-02 9:10:00 AM weatherXML saveIconCondition: http://icons.wxug.com/i/c/j/cloudy.gif
    4th line down - there's a / in that path that should be a \? Is that it?
    If so, that's a bug I'm guessing.
      Still hitting this (now on 3.0.0.73) and it would be great to figure out why this error appears in my log every ten mins if possible. Newest at top
      Sep-17 8:50:01 AM Warning Image file does not exist, returning blank image: C:\Program Files\HomeSeer HS3\html\0
      Sep-17 8:50:01 AM weatherXML Use File: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\partlycloudy_0.gif
      Sep-17 8:50:01 AM weatherXML Use image: /images/weatherXML/condition/partlycloudy_0.gif for HSTouch
      Sep-17 8:50:01 AM weatherXML Check for refID: 4456
      Sep-17 8:50:01 AM weatherXML Found RefID: 4456
      Sep-17 8:50:01 AM weatherXML Check if address exists: Location 1 HST Condition Icon
      Sep-17 8:50:01 AM weatherXML Check for replace with
      Sep-17 8:50:01 AM weatherXML Check for refID: 4455
      Sep-17 8:50:01 AM weatherXML Found RefID: 4455
      Sep-17 8:50:01 AM weatherXML Found RefID: 4624
      Sep-17 8:50:01 AM weatherXML Check if address exists: Location 1 Condition
      Sep-17 8:50:01 AM weatherXML Save to: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\partlycloudy_0.gif
      Sep-17 8:50:01 AM weatherXML Downloading the weatherXML: curcond.jpg file at http://icons.wxug.com/i/c/k/partlycloudy.gif.
      Sep-17 8:50:01 AM weatherXML Replacement URL: http://icons.wxug.com/i/c/k/partlycloudy.gif
      Sep-17 8:50:01 AM weatherXML Save condition image to: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\curcond1.jpg
      Sep-17 8:50:01 AM weatherXML Download image: http://icons.wxug.com/i/c/k/partlycloudy.gif
      Sep-17 8:50:01 AM weatherXML saveIconCondition: http://icons.wxug.com/i/c/k/partlycloudy.gif
      Sep-17 8:50:01 AM weatherXML Set Condition: Partly Cloudy
      Sep-17 8:50:01 AM weatherXML Condition
        I've added some more log entries to try to figure out exactly where the error is happening. Since the weatherXML plugin is not the one creating the error message I don't know the exact location where it is happening. The error logs you put in your post narrow it down but don't pinpoint it.
        When version .75 is released and you get this error, please grab the lines that you did plus one or two after the error.
        Jeff Farmer
        HS 3, HSPhone
          Thanks Jeff, I'll update to the newer build when it's available and report back.
            I updated to 3.0.0.76 and enabled debug logging. This is what leads to those errors - the file named right below the errors, nt_mostlycloudy_0.gif, is right there, where it should be.
            Oct-16 8:20:01 PM Warning Image file does not exist, returning blank image: C:\Program Files\HomeSeer HS3\html\0
            Oct-16 8:20:01 PM weatherXML Use File: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\nt_mostlycloudy_0.gif
            Oct-16 8:20:01 PM weatherXML Use image: /images/weatherXML/condition/nt_mostlycloudy_0.gif for HSTouch
            Oct-16 8:20:01 PM weatherXML Check for refID: 4456
            Oct-16 8:20:01 PM weatherXML Found RefID: 4456
            Oct-16 8:20:01 PM weatherXML Check if address exists: Location 1 HST Condition Icon
            Oct-16 8:20:01 PM weatherXML Check for replace with
            Oct-16 8:20:01 PM weatherXML Check for refID: 4455
            Oct-16 8:20:01 PM weatherXML Found RefID: 4455
            Oct-16 8:20:01 PM weatherXML Found RefID: 4624
            Oct-16 8:20:01 PM weatherXML Check if address exists: Location 1 Condition
            Oct-16 8:20:01 PM weatherXML Save to: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\nt_mostlycloudy_0.gif
            Oct-16 8:20:01 PM weatherXML Downloading the weatherXML: curcond.jpg file at http://icons.wxug.com/i/c/k/nt_mostlycloudy.gif.
            Oct-16 8:20:01 PM weatherXML Replacement URL: http://icons.wxug.com/i/c/k/nt_mostlycloudy.gif
            Oct-16 8:20:01 PM weatherXML Save condition image to: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\curcond1.jpg
            Oct-16 8:20:01 PM weatherXML Download image: http://icons.wxug.com/i/c/k/nt_mostlycloudy.gif
            Oct-16 8:20:01 PM weatherXML saveIconCondition: http://icons.wxug.com/i/c/k/nt_mostlycloudy.gif
            Oct-16 8:20:01 PM weatherXML Set Condition: Mostly Cloudy
              Can you confirm that this file exists?
              Keep in mind that on linux the directories are case sensitive.
              Make sure each of the directories in the above path and the image name match the case exactly.
              Jeff Farmer
              HS 3, HSPhone
                Yes indeed. File(s) are exactly in that path. If I copy and paste that path into Start/Run it opens the gif directly.
                  I finally managed to track this down. One HS Touch device was the cause - once I deleted that it went away.
                    I'm getting tons of refID entries every hour in my log, like so:
                    Apr-16 11:01:01 AM weatherXML Check for refID: -1
                    Anything I need to fix here?
                      Go to the Settings tab. Set the logging level to Errors.
                      Jeff Farmer
                      HS 3, HSPhone
                        Will do. So I presume that's not an error condition that requires attention?
                          Correct. It just means that in the course of importing the data it was checking for each type of device that can be created and it did not find some of them. It will still save the data, there just wasn't a device that needed to be set.
                          Jeff Farmer
                          HS 3, HSPhone
                            Noted. Thanks for the quick response. Set the log level and no more cleanup on aisle 3!
                              Bringing this thread back to life as I have finally found why I constantly get errors every 10 minutes. I had just been living with it every 10 minutes but because of this post and my using TenHsEvents I found the root cause.
                              Every ten minutes I get this
                              Sep-21 10:22:01 AM Warning Image file does not exist, returning blank image: C:\Program Files\HomeSeer HS3\html\0
                              This gets thrown when my Current Condition Icon gets updated every 10 minutes, I use that device in HS Touch.
                              TenHsEvents tells me that this device briefly changes to -999 in value, then back to 100. When it briefly changes to -999 I get the error logged as there is no image associated with value -999.
                              So I added a single value for that device, assigned a black box image, and the error went away. But then the device value was removed by the PI and so 10 minutes later it was back.
                              So now I know why, but I can't fix. Jeff, can you help?
