Error in Event Log When PI Tries to Download Conditions
    #16
    The reason I do the value change is that if I just change the image to the new condition, provider, etc. image, HSTouch will not register that change until there is a device value changed. I'll look at the code and see what I can come up with.
    I haven't been around much as we are converting our unfinished basement into a living space and almost all my spare time has been working on that. I will look at the code this afternoon and come up with a way to bypass it getting changed as the new image is being added.
    Jeff Farmer
    HS 3, HSPhone
      #17
      Thanks Jeff, really appreciate it. It's cosmetic really, my event log simply fills with these events, but if there is a simple fix it would be appreciated. I can't be the only person seeing this. As I said before, I did create a static -999 status value for the device (with an image I picked, but not sure how necessary that is) and it suppressed the message - but then that value was deleted from the device. So I was back to square 1. Would setting (and leaving) a status image for -999 work?
        #18
        I could sworn I got an email saying you had a solution to this to try - and now it's not there... lost when the forum took a dump the other day? Or my imagination..
