Jeff,
So I thought I'd use WeatherXml to help out with what appears to be issues with McsSprinkler (well... at least in my case) weather/watering management.
As you can appreciate, successful irrigation is heavily dependent on weather input data to the plugin. So Michael had provisioned the use of external sources for wind, rain, UV and such. However, mcsSprinkler is a port from HS2 and thus uses X-10 style device codes for devices. I thought I'd take advantage of a couple of devices from your plugin - but there were no device codes (old style) set in them. So I added my own keeping an eye on what was available to use. In any case, the Location Technology Address seems to get appended with numerous device codes. I'm thinking when it is getting updated by the plugin. Is there a possibility that this can get fixed?
See image for the UV device which I added the device code of S104. It just keeps on appending...
