Not speaking any more?
    Hi, I came back from my vacation and weatherxml has been issuing this message and it doesnt speak any more any ideas? thanks
    Sep-27 8:16:00 AM weatherXML Error Download Maps: Index was outside the bounds of the array.
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    Whenever I see the array bounds error it typically means that an ini file has gotten corrupted.
    In this case it is the maps file. Check your backups and replace the weatherMap.ini.
    The current beta is .76 and has removed the usage of an ini file for map setup.
    Jeff Farmer
    HS 3, HSPhone
      When will the beta be official ?
      Hector
      Win.2003 OS, HS3
        It is ready now. I haven't moved it from the beta section of the updater due to the big change in maps. But if your ini file is corrupt the new version won't be able to import your previous maps.
        Jeff Farmer
        HS 3, HSPhone
          Jeff, my backup INI didn't work I have the same issue,what else can I do to fix this?
          Hector
          Win.2003 OS, HS3
            Shut down the plug-in. Delete the weathermap.ini file. Reinstall from the updater and start the plug-in. That will reset the maps.
            Jeff Farmer
            HS 3, HSPhone
              Jeff ,looked at the config folder in hs3 , didn't find the weathermap.ini. In what folder should it be?
              Hector
              Win.2003 OS, HS3
                Never mind Jeff , I found it. I deleted and reinstalled. Restarted it ,after a while the message popped up again. I kinda don't understand why the speak devices don't work with this kind of map error .
                Hector
                Win.2003 OS, HS3
                  My guess is the error is not letting the plugin load all the way.
                  Can you get to any of the admin web pages? If so, set the logging level to Debug. Stop the plugin, restart the plugin and check the logs for any weatherXML errors.
                  Get me the log entries. Not just the error ones, but several before the error and several after the error.
                  Jeff Farmer
                  HS 3, HSPhone
                    heres the log jeff
                    Hector
                    Win.2003 OS, HS3
                      Since the map ini file is corrupted, I would suggest you go ahead and start using the beta version. On the updater page, scroll down to the beta section and install version .76.
                      The maps section has been rewritten to not use an ini file and there is a new pdf file with instructions for the maps section.
                      Jeff Farmer
                      HS 3, HSPhone
                        Jef, installed beta, but still have same errors and speak devices don't work. When you activate a speak device I can see the HS ballon that pops up empty. Normally you will see text that being spoken.
                        Hector
                        Win.2003 OS, HS3
                          I don't see how you can be getting the same error. The function that used to give the "Download Maps:" error is no longer even in the plugin.
                          It was removed when the maps ini file stopped being used.
                          Set the HS device management page to show the speak devices.
                          When you click the Text button for one of them does the text update?
                          For your speak devices, click on the device name to go to the edit screens. Click the weatherXML tab, what Speaker Client do you have set to send the speaking to? Is that client connected?
                          Jeff Farmer
                          HS 3, HSPhone
                            Set the logging level to debug. Go to your speak devices and click on the Speak button for one of them. Set the logging level back to errors.
                            Check the HS log to see if there are any errors?
                            Jeff Farmer
                            HS 3, HSPhone
                              this is what I get:
                              Message/Source
                              Oct-01 8:35:09 AM TTS Speak (*:*):
                              Oct-01 8:35:09 AM weatherXML Error getPHLocationCity: Index was outside the bounds of the array.
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Day 10
                              Oct-01 8:35:09 AM weatherXML Error getForecastDayValue: Index was outside the bounds of the array.
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Day 9
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Day 8
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Day 7
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Day 6
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Day 5
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Day 4
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Day 3
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Day 2
                              Oct-01 8:35:09 AM weatherXML Found RefID: 273
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Tomorrow Night
                              Oct-01 8:35:09 AM weatherXML Found RefID: 272
                              Oct-01 8:35:09 AM weatherXML Found RefID: 239
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Tonight
                              Oct-01 8:35:09 AM weatherXML Found RefID: 237
                              Oct-01 8:35:09 AM weatherXML Check if address exists: Location 1 Forecast Today
                              Oct-01 8:35:09 AM weatherXML Error replaceWVariables: Index was outside the bounds of the array.
                              Oct-01 8:35:09 AM weatherXML Error speakText: Index was outside the bounds of the array.
                              Oct-01 8:35:09 AM weatherXML SetIOMulti Text: , Value: 0, refID: 846
                              Oct-01 8:35:09 AM Device Control Device: Speak Items weatherXML Speak Temperature to Speak (0) by/from: CAPI Control Handler
                              Hector
                              Win.2003 OS, HS3
