Jeff, I've been trotting through WeatherXML through the various tabs/setups and using your documentation where available but I'm having great difficulty getting Maps to appear I have devices with broken links being displayed so I'm assuming that something is afoul.
Maps
Maps
Computer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.16.0
Plug-Ins: AmbientWeather 3.0.1.9,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLRoombaWifi 2.0.37.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.4,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,rnbWeather 4.4.0.0,SDJ-Health 3.1.1.2,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.31.0,Z-Wave 3.0.10.0,Z-Wave Parameters 4.0.55.0,Z-Wave UI 1.0.0.0, and Jon00 scripts.Tags: None
Download version .76. The Map section has been rewritten and there is a pdf file for documentation. And it doesn't use an ini file for the settings.--
Jeff Farmer
HS 3, HSPhone
Jeff, another newbie question. I noticed that when I create an event using any of the WeatherXML devices e.g. "Current Condition" when I try to establish a trigger I would have expected to see a list of valid conditions like Clear, Rainy, Fog ect.. but instead I'm presented with "Custom value or Value Range of". Am I missing something and is there a cheat sheet for acceptable values? MikeComputer: CUK Intel NUC7i7BNH
The weatherXML devices that have numbers for the values can be used to trigger events. For conditions, look in the event triggers for weatherXML Triggers. You can select Condition and then enter Contains, Not Contains, or Equals and in the textbox enter one or several Condtions that you want to match on.--
Jeff Farmer
HS 3, HSPhone
Jeff, Looking at your word file, other than the temperature7Day_1.png and forecastMultiDay_1.png files that are being created my WeatherXML. The radar and other files are somehow being created some other way. I tried your URL's but they seem to be dated (don't work anymore). I tried using wunderground radar tool for my area (see below), it works within the browser but does not display within the WeatherXML device (broken link), looking at your examples each one seems to be either a Gif or JPG file which I'm not clear how to make these available? More clues please, Mike
Code:https://www.wunderground.com/wundermap?lat=42.20&lon=-75.98&zoom=8&rad=1&wxsn=0&svr=0&cams=0&sat=0&riv=0&mm=0&hur=0
Jeff, thanxs for steer, did not think about weatherXML triggers (getting late), I assume that if I have several conditions they are separated with a comma or space delimiter?
The weatherXML devices that have numbers for the values can be used to trigger events. For conditions, look in the event triggers for weatherXML Triggers. You can select Condition and then enter Contains, Not Contains, or Equals and in the textbox enter one or several Condtions that you want to match on.Computer: CUK Intel NUC7i7BNH
Originally posted by MNB View PostJeff, thanxs for steer, did not think about weatherXML triggers (getting late), I assume that if I have several conditions they are separated with a comma or space delimiter?--
Jeff Farmer
HS 3, HSPhone
Originally posted by MNB View PostJeff, Looking at your word file, other than the temperature7Day_1.png and forecastMultiDay_1.png files that are being created my WeatherXML. The radar and other files are somehow being created some other way. I tried your URL's but they seem to be dated (don't work anymore). I tried using wunderground radar tool for my area (see below), it works within the browser but does not display within the WeatherXML device (broken link), looking at your examples each one seems to be either a Gif or JPG file which I'm not clear how to make these available? More clues please, Mike
The radar map is setup on the locations page. See the image below.
After setting the 3 options, go to the Schedules page and make sure that the Maps schedule is set to run. When the map schedule runs, it will loop over your entered maps and download the radar map and the ones that you have set by setting the download checkbox.
I really recommend that you upgrade to version .76 which is in the updater now. There is a pdf document for the maps section which is handled quite a bit differently. The checkboxes for download and device are gone hopefully making things less confusing and the example images are coming from my HS3 setup.--
Jeff Farmer
HS 3, HSPhone
Jeff, many thanxs for the update PI and document(s) with working examples it makes it a little more coherent and I was able to set-up both Maps and charts. Question not clear as to how one established "Map Rotation" Device I can see what it looks like but.. more clues please, MikeComputer: CUK Intel NUC7i7BNH
Originally posted by MNB View PostJeff, many thanxs for the update PI and document(s) with working examples it makes it a little more coherent and I was able to set-up both Maps and charts. Question not clear as to how one established "Map Rotation" Device I can see what it looks like but.. more clues please, Mike
Go to the HS Device Management page, find your map devices. Each location will have a Map Group parent. Click on the name to edit the device. On the page where you can see the tabs for Status Graphics, there should be one at the end labeled weatherXML. Click on that tab. There is a dropdown to select Yes or No for having a map rotation device created.--
Jeff Farmer
HS 3, HSPhone
Originally posted by MNB View PostLast question, looking at my wind speed and degrees I seem to be getting -9999 value which also shows up when use a speak device see attached. I would have thought it would have a value of 0 for wind speed and 000 for degrees (North), any suggestions?
I would need to see the xml file to confirm if the value is wrong in the data or wrong in the import.
If you go to the weatherXML admin pages, to the one labeled Devices, there is a textbox where you can enter the value to be used for an invalid value during import. I will have to check to see for sure which fields get set to that invalid value. At some point I need to change that and set it so that you can enter the value you want to be used for invalid is settable by each data type.
It will most likely be this weekend before I have a chance to look into this.--
Jeff Farmer
HS 3, HSPhone
Jeff, thanxs for taking the time to support. I've verified that "Invalid Value" is set to -9999.
It will most likely be this weekend before I have a chance to look into this.Computer: CUK Intel NUC7i7BNH
Jeff, found the Map Rotation device, thanxs I believe I'm now up and running weatherXML with exception of the -9999 issue and will await your update, thanxs in advance, MikeComputer: CUK Intel NUC7i7BNH
I've looked everywhere within the PI Tabs for Forecast Chart Image Setup (10 day Hourly Temperature Chart) and Temperature Chart Image Setup (7 day Historical Temperature Chart) can someone point me in the correct direction? MikeComputer: CUK Intel NUC7i7BNH
