Dark Radar Images
    Dark Radar Images
    This happens every now and then, but it's been all day today.
    How do I prevent the image from being dark?
    Still happening. Why?
      ...still happening. What gives?
        I am seeing the same thing. Not always, but frequently. I am running version 3.0.0.76 of the plugin.
          I have not been able to duplicate it.
          Have you looked in the HS log to see if there are any errors?
          If you delete the dark image, does a new one get downloaded?
          Jeff Farmer
          HS 3, HSPhone
            No errors in the log for me. I don't really need to do anything special to correct the dark image. I just check the radar map later and it is fine again. It almost seems like the dark image is there for a download, then a normal image is there on a subsequent download. I will pay close attention now and see if the dark image is tied to the download schedule.
              Definitely occurring on the schedule for the Maps download. My radar map was normal, then my 6:46pm map download schedule occurred, and now I have the dark image. No errors in the log. I will check again when the 7:46pm schedule runs.
                No errors in my log. Dark map comes and goes, as other user reports, too.
                But 95% of the time, it's dark now.
                Update: my current map is normal, so I forced an update, and it's still normal.
                Ironically, my scheduled update for maps occurred right after this, and the map didn't update, although the file date is new. I think I am going to disable this until the WeatherXML schedule, and just continue using my 15-minute event schedule within HS.
                  I spoke too soon. One of my 15 minute scheduled updates just ran, and the map is back to dark.
                  If it helps, the first frame of the GIF is normal and the rest are dark. I then deleted the GIF, and ran the update manually from within the WeatherXML schedule page, and it re-created it with the same first frame normal and remainder dark.
                    Bump
                      I have tried to duplicate this on 2 different installs, once of which I have 3 locations setup that all 3 are downloading the radar image.
                      None of the 4 maps are dark.
                      I don't know what to have you try.
                      Jeff Farmer
                      HS 3, HSPhone
                        Jeff, what is the URL that the animated radar is downloaded from? Or do you render that animated GIF somehow? I am seeing this dark map very frequently as well, and want to try and help dig in and see why this may be happening. I have been using the Animated Radar Map in my WeatherXML installation for years, and this only started occurring in the last few months.
                          Yup, same here.
                          I'm assuming you're using Weather Underground as well? And I want to help too, but it sounds like you don't have a starting point for us yet. I was thinking about changing my location Station ID temporarily to see if that has any effect on how the map is generated.
                          Just FYI, when those dark maps are generated, the first frame is of normal color, but the remainder is dark and I've noticed it never shows any precipitation.
                            I changed my station ID to another local one, modified my LAT/LON by a hair, and changed my map radius from 85 to 80. The next update grabbed a proper map. Maybe coincidence or maybe it had something to do with it. We'll see.
                              Yup, same here.
                              Yes, I am also using Weather Underground. I am seeing exactly the same behavior.
                              Great point! Jeff could actually change the Station ID on one of his test installations to your ID or mine and see if he can reproduce the problem. For me, the dark map occurs many times throughout the day, so I am certain he would see it.
