I just downloaded and installed the latest version of the plug-in. After I was done, the plug-in no longer appears in my plug-in list even though the log contains the download and install discourse. I tried to download from the Additional Interfaces list with the same result. Task Manager does not show HSPI_WeatherXML as a running process.
Is it really there, but invisible? What happened?
Mar-16 5:02:54 PM Updater Install/Update of package weatherXML was successful.
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXML.doc
Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\scripts\weatherXML_HSPhone.vb
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLVarsPluginInt.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLPluginInt.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLValueDevices.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLDatabase.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLMiscDevices.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLSchedules.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLSpeakDevices.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLMapDevices.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLLocations.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLGeneralSettings.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\hspi_weatherXML\weatherXMLQuickStart.pdf
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\Docs\weatherXML\hstouch.zip
Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Data\weatherXML\backup\backup.txt
Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Data\weatherXML\weatherXML.mdb
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\Docs\weatherXML\weatherXML.doc
Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\weatherXML\weatherTriggers.ini
Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\weatherXML\weatherInfo.ini
Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\Config\hspi_weatherXML.ini
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\weatherXML\Linux_System.Data.SQLite.dll
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\weatherXML\Windows_System.Data.SQLite.dll
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\weatherXML\Newtonsoft.Json.dll
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\weatherXML\SQLite.Interop.dll
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_WEATHERXML.exe.config
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\up.png
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\down.png
Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\html\images\weatherXML\maps\SunMap.png
Mar-16 5:02:54 PM Updater Warning File exists, not overwriting: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\curcond.jpg
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\SunSurf.png
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\SunSpeak.png
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\SunMap.png
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\Sun.png
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\sun.gif
Mar-16 5:02:54 PM Updater Copying file: C:\Program Files\HomeSeer HS3\html\images\weatherXML\atom.jpg
Mar-16 5:02:54 PM Updater Extraction Complete.
Mar-16 5:02:54 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\wind.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\wind\
Mar-16 5:02:54 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\thermos.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\thermos\
Mar-16 5:02:54 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\other.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\other\
Mar-16 5:02:54 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\moon2.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\moon2\
Mar-16 5:02:54 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\moon.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\moon\
Mar-16 5:02:53 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\dewpoint.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\dewpoint\
Mar-16 5:02:53 PM Updater Extraction Complete.
Mar-16 5:02:53 PM Updater Extracting files from zip file: C:\Program Files\HomeSeer HS3\Updates3\weatherXML3.0.0.83\barometric.zip Destination: C:\Program Files\HomeSeer HS3\html\images\weatherXML\barometric\
Mar-16 5:02:52 PM Updater Installing package weatherXML
Mar-16 5:02:52 PM Updater Update HSPI_WEATHERXML.exe downloaded successfully
Mar-16 5:02:48 PM Updater Downloading update: weatherXML
