NOAA Forecast and Alerts stopped working
    After the 4:05 pm update on April 2, the import of forecasts and alerts from NOAA stopped working. Conditions import works for data, but errors sometimes on the image. If I click on the links in a browser, it successfully loads the web page. Using version 3.0.0.83. I have made no changes to my setup. Log errors are as follows:
    for Alerts:
    Apr-04 9:15:00 AM weatherXML Error downloadFile: NOAA Weather Alerts from: http://alerts.weather.gov/cap/wwaatm...p?x=NCC081&y=0. Error: The underlying connection was closed: An unexpected error occurred on a send.
    For forecasts:
    Apr-04 9:23:13 AM weatherXML Error File: C:\Program Files\HomeSeer HS3\Data\weatherXML\NOForecast1.xml does not exist. Unable to continue import.
    Apr-04 9:23:13 AM weatherXML Error downloadFile: NOAA Weather Forecast from: http://forecast.weather.gov/MapClick...&FcstType=dwml. Error: The underlying connection was closed: An unexpected error occurred on a send.
    Apr-04 9:22:59 AM weatherXML Error downloadFile: weatherXML: curcond.jpg from: http://forecast.weather.gov/images/wtf/small/bkn.png. Error: The underlying connection was closed: An unexpected error occurred on a send.
    For conditions:
    Apr-04 6:05:00 AM weatherXML Error downloadFile: weatherXML: curcond.jpg from: http://forecast.weather.gov/images/wtf/small/novc.png. Error: The underlying connection was closed: An unexpected error occurred on a send.
    Any help greatly appreciated!
    Fred
    HomeSeer Pro 3.0.0.548, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
    I'm seeing the same error messages.
    Dick
    HS PRO 2.5.0.81, WinXP, IE8, Shuttle XS35V3, 2.13GHz, 4GB, 40GB SSD drive, AC-RF2, ADIOcelot, Message Server, TI103, SNEVL CID, pjcOutlook, MCSTemperature, Powertrigger, BLBackup, BLFloorplan, BLIcon, BLOccupied, BLRadar, BLRfid, BLLogMonitor, ACPUPSD, UltraECM, WeatherXML & Stipus' script connector. 500+ devices, 260+ events, 1-wire weather station + temp/humidity sensors & Oregon Scientific temp & humidity sensors & 2 Brultech ECM-1240s
      I began seeing exactly the same messages as well, beginning with my 16:15 EDT update on April 2. Thinking it was my system, I restarted the plugin, restarted HS3, cold started my machine, all to no avail. I also replicated that the URL works in a browser. Your report pretty much confirms it is probably an issue at NOAA. The only difference I see is that I am using version 3.0.0.73. Incidentally, I only noticed this yesterday when I happened to check the log because my wife noted that the system spoke a forecast that didn't make sense... I don't check the log daily. I wish there was a way to get a notification whenever the log records such errors.
        For the alerts the URL is entered wrong.
        On the page to setup the alerts the url starts with:
        In the textbox you need to have:
        /cap/ks.php?x=0
        The only change would be to replace the ks with the 2 letter abbreviation for your state.
        Anything else will not return an xml file that can be imported.
        For the conditions and forecast, I'll keep an eye on my setup tomorrow to see if I can duplicate this.
        for Alerts:
        For forecasts:
        For conditions:
        Jeff Farmer
        HS 3, HSPhone
          Thanks, Jeff. Made the change. Still getting the error. As before, going to the URL with a browser returns the XML page.
          Apr-05 9:55:00 AM weatherXML Error downloadFile: NOAA Weather Alerts from: http://alerts.weather.gov/cap/nc.php?x=0. Error: The underlying connection was closed: An unexpected error occurred on a send.
          Fred
            I've been running 2 locations using NOAA and have not gotten any errors.
            Can you try stopping the plugin and restarting it?
            See if that clears whatever is keeping the files from downloading.
            Jeff Farmer
            HS 3, HSPhone
              Hmmm... I can report that I tried restarting the plugin (along with restarting everything else including the machine) to no avail. Note that when I first noticed the issue I was on version 3.0.0.73, and yesterday I updated to the current version, but the error keeps on comin'.
              - Bill
                Have tried all the following, error still exists.
                1. Stop/start plugin
                2. Stop/start HS3
                3. Change latitude/longitude, then restart plugin
                One thing I noticed is that if I bring up the forecast page in a browser, I get a message at the top that says "This XML file does not appear to have any style information associated with it. The document tree is shown below." May have absolutely nothing to do with the problem, but thought I should mention it.
                Jeff, could you give us the latitude/longitude of a location that's working for you and let us try it?
                Thanks!
                Fred
                  Jeff,
                  I created a new location to see if that would make any difference. Still errors out. Here's the "debug mode" log entries.
                  Apr-07 10:28:50 AM weatherXML Download Status: Failure
                  Apr-07 10:28:50 AM weatherXML Error downloadFile: NOAA Weather Forecast from: http://forecast.weather.gov/MapClick...&FcstType=dwml. Error: The underlying connection was closed: An unexpected error occurred on a send.
                  Apr-07 10:28:49 AM weatherXML Downloading the NOAA Weather Forecast file at http://forecast.weather.gov/MapClick...&FcstType=dwml.
                  Apr-07 10:28:49 AM weatherXML Replacement URL: http://forecast.weather.gov/MapClick...&FcstType=dwml
                  Apr-07 10:28:49 AM weatherXML Forecast Source: noaa
                  Apr-07 10:28:49 AM weatherXML Running Forecast
                  Apr-07 10:28:32 AM weatherXML page: weatherXML_loc, data: locNOAAForecastlon_3=-79.9742
                  Apr-07 10:28:23 AM weatherXML Locations Allowed: 10, In Use: 3
                  Apr-07 10:28:23 AM weatherXML Found RefID: 311
                  Apr-07 10:28:23 AM weatherXML Check if this address exists: Location 3 Map Group
                  Apr-07 10:28:23 AM weatherXML Found RefID: 220
                  Apr-07 10:28:23 AM weatherXML Check if this address exists: Speak Items Root
                  Apr-07 10:28:23 AM weatherXML page: weatherXML_loc, data: id=deviceSelector&deviceSelector=3
                  Apr-07 10:28:15 AM weatherXML Locations Allowed: 10, In Use: 3
                  Apr-07 10:28:15 AM weatherXML Found RefID: 289
                  Apr-07 10:28:15 AM weatherXML Check if this address exists: Location 1 Map Group
                  Apr-07 10:28:15 AM weatherXML Found RefID: 220
                  Apr-07 10:28:15 AM weatherXML Check if this address exists: Speak Items Root
                  Fred
                    Here is what I am using for the location I have setup to use NOAA.
                    For current conditions:
                    KLWC
                    For Forecast:
                    Latitude: 38.93721329
                    Longitude: -95.21652899
                    Alerts:
                    /cap/ks.php?x=0
                    The thing that stands out as weird on your error logs is that it says:
                    It's not erroring on what would normally be sent back to you. It is erroring on the outgoing. On sending from the HS comoputer.
                    Are you running Windows 10? If so, have you had any recent updates from Microsoft? Wondering if something got updated and isn't letting the request out.
                    Jeff Farmer
                    HS 3, HSPhone
                      Similarly, I also ran debug logging:
                      Apr-06 17:01:00 weatherXML Staus: Failure
                      Apr-06 17:01:00 weatherXML Error downloadFile: NOAA Weather Alerts from: http://alerts.weather.gov/cap/wwaatm...p?x=OHZ078&y=0. Error: The underlying connection was closed: An unexpected error occurred on a send.
                      Apr-06 17:01:00 weatherXML Downloading the NOAA Weather Alerts file at http://alerts.weather.gov/cap/wwaatm...p?x=OHZ078&y=0.
                      Apr-06 17:01:00 weatherXML Replacement URL: http://alerts.weather.gov/cap/wwaatm...p?x=OHZ078&y=0
                      Apr-06 17:01:00 weatherXML URL: http://alerts.weather.gov/cap/wwaatm...p?x=OHZ078&y=0
                      Apr-06 17:01:00 weatherXML Last Update: 04.02.18 16:00:58
                      Apr-06 17:01:00 weatherXML Alert to check: 1
                      Apr-06 17:01:00 weatherXML Existing alert file last updated at 2018-04-02T20:00:58+00:00
                      Apr-06 17:01:00 weatherXML The file C:\Program Files\HomeSeer HS3\Data\weatherXML\NOAlerts1.xml is ready for import.
                      Apr-06 17:01:00 weatherXML Running Alert for location 1
                      Apr-06 17:01:00 weatherXML Triggers to check: 0
                      Apr-06 17:01:00 weatherXML Check for timer items to run
                      Apr-06 17:00:00 weatherXML Check for timer items to run
                      In my case, the machine is running XP so I'm pretty sure there were no OS updates. I will check to see if maybe a router or cable modem received an update, but what are the odds that all three of us had equipment updates at the same time? This is an odd one.
                      - Bill
                        Nope. Running XP with updates turned off. I tried a new location with your settings. Same Error.
                        I did notice one thing - when you enter the URL in a browser, it gets changed from http: to https:. Is it possible that that isn't happening when WXML tries to access the page and maybe NOAA now requires https?
                        Fred
                          Have discovered this is NOT a WeatherXML problem. Installed test setup of HS on a Win10 machine. Copied over WXML settings from the XP machine. Everything about WXML runs fine! This eliminates network, router, etc. problems as a possible cause. Also turned off firewall on the XP machine to see if that could be the problem. That didn't help.
                          I'm now suspecting an expired certificate on XP. Still investigating. Will post more when I have some answers.
                          Fred
                            That's a step forward! Seems we are all using XP. The good news is, regarding the current conditions, is that although I still get "downloadFile: weatherXML: curcond.jpg from: http://forecast.weather.gov/images/wtf/small/skc.png. Error: The underlying connection was closed: An unexpected error occurred on a send", the database still populates the data as seen on the user pages/data page. Seems it only fails when it gets to the skc.png image file. Not sure why that would be.
                              Arrrrrgh! Took me hours to find out how to update the certificates in XP. But that didn't solve the problem!
                              Is anyone using WeatherXML on an XP machine and still have forecasts working?
                              Fred
