Questions about syntax for use of trigger in event
    What I am trying to do is use the current condition for my location in an event. My questions:
    1) Is it case sensitive? For example, is "Rain" the same as "rain?"
    2) When using more than one condition, each is separated by a comma. Does a space after the comma make a difference?
    3) How would two words in a condition be handled, such as "partly cloudy?"
    Elliott
    "Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
    Elliott
    1. It is not case sensitive.
    2. Current version, the space would make a difference. While I was checking the code I went ahead and set it to ignore leading or trailing spaces. The next version released will have this change.
    3. It would only match on "partly cloudy". It would not match on "partly sunny and cloudy". It would match on "Sunny and partly cloudy"
    Jeff Farmer
    HS 3, HSPhone
      Thank you. This is helpful.
      Elliott
