Daily forecast stuck on Wednesday
  • Daily forecast stuck on Wednesday
    Hello Jeff
    I have a speak daily forecast that is stuck on a particular day (Wednesday), this just happened all of a sudden. Can it be a corrupted data base?
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    No, the only thing a database is used for in weatherXML is to store old data.
    The current info is read from a file and stored in memory.
    When there is an issue the first thing to do is check the logs. Look for an error. After that, check the Schedules page and make sure all of the items are set to active. It will show the date and time the schedule last ran.
    Check to see if a new file is in the data/weatherxml folder. Check the file for actual data.
    Jeff Farmer
    HS 3, HSPhone
      thanks Jeff
      found this error in the log:
      Jun-05 6:16:07 AM weatherXML Error importForecastHourly: Input string was not in a correct format.
      Hector
      Win.2003 OS, HS3
        That error is fixed in the new version in the updater. V.87
        Jeff Farmer
        HS 3, HSPhone
          Ok thank you
          Hector
          Win.2003 OS, HS3
            Did updating take care of things for you?
            Jeff Farmer
            HS 3, HSPhone
              Yes sir it did thank you.
              Hector
              Win.2003 OS, HS3
