Index is outside of matrix boundaries
  • Index is outside of matrix boundaries
    Since a while, my weather xml stopped updating. When I open most of the settings pages (location settings, database, advanced, ...), I get the above error message. What is wrong?
    Kristof.
    It sounds like one of the ini files has gotten corrupted.
    Stop the weatherXML plugin.
    You will need to go into one of your backups and grab the files in the HomeSeer HS3\config\weatherXML directory. Copy them from your backup to the directory in your HS install.
    Restart weatherXML.
    Jeff Farmer
    HS 3, HSPhone
      Perfect, that did the trick. Restored the files from a backup the day before the last update of the devices. Running again as it should.
      Thank you for the advise.
