Displaying Animated Map In HSTouch Default Screens
  • Displaying Animated Map In HSTouch Default Screens
    Can you display animated maps or regular maps in HSTouch default screens? I have a map that works in homeseer device management screen when selecting weatherxml and web pages. It also shows up in the device management icon but of course is very small. I have the url entered to download the map. However when I go to the HSTouch Screens it shows the map device that I created with a non animated icon of the map (very small) on the left as it is displayed in the device management screen. Does not display large enough to where you can see any detail.....Rick
    Last edited by Rick Bonari; June 11th, 2018, 01:13 AM. Reason: Additional Information
    you can set the element of a text box to any html page/image you like. to adjust the image size you can use an html tag like...
    <img src="http://images.intellicast.com/WxImages/RadarLoop/lwt_None_anim.gif" width="1100" height="750">
      What you are referring to are custom screens in hstouch. I am using the generic default homeseer screens where you don't have much flexibility to change or modify screens.
      My question refers to incorporating useful map displays in hstouch default screens?
      Thanks Much !!!!!! Rick
        You aren't going to get much in default projects when it comes to maps.
        When you setup a device to display a map, you will see a small map as the HSTouch default pages will display the map at the size it displays device status icons.
        Jeff Farmer
        HS 3, HSPhone
          To display images that change regularly in HSTouch, I use a script to upload a image to a device and rotate it at regular intervals.
          For more information, see this post, https://forums.homeseer.com/showpost...7&postcount=31
          Billy Draper
