Forecasts Schedule causing error
    Hi Jeff,
    I have had a nagging issue in HS3 where I get a error. Rich did not think it was anything to worry about, but I finally tracked it down.
    In my schedule, I have the Forecast set to go at 3 minutes after the hour. Not sure if it is running or not, but every time it runs, this is in the log:
    Jun-17 15:18:57 Error BuildDeviceVoiceCommands error (1), Object reference not set to an instance of an object., Scheduler
    Jun-17 15:18:56 Error BuildDeviceVoiceCommands error (1), Object reference not set to an instance of an object., Scheduler
    I just verified it but running it manually at 15:18 and this showed up in the log. I am running HS3 .445 and XMLWeather .87
    Do I need to change something?
    Michael
    HS3Pro & HS4Pro on Win2012R2
    Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
    BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
    BuildDeviceVoiceCommands is not a function in the weatherXML plugin.
    You might check your forecast devices and see if you have them set to be a voice command device. The checkbox is on the Configuration tab of a device.
    Jeff Farmer
    HS 3, HSPhone
      Thanks. I removed them earlier. Thanks Jeff. I will keep pushing on HS about this.
      Michael
