weather underground not accurate ?
    Hi all
    I'm using weather underground.
    But my problem is the temperature is not accurate.
    like today with humudity it feel 36 celcius.
    But in weather xml its telling me feel like 25 celcius
    the object has been updating like 5 min ago
    any idea why it is not accurate ?
    thx
    Couple of things
    Make sure your lat and long are correct.
    Is the feels like updating at all. You can check the Last updated time on that device.
    Jeff Farmer
    HS 3, HSPhone
      I know what you mean... I use weatherXML which uses WU and noticed the same thing - though I use it mainly for forecast information for my irrigation. I've been using Wadenut's script for years now found here which gets info from Environment Canada which is accurate.
      Robert
      EDIT: Jeff, it appears some things like humidity are ok. Right now WU reports that it is 21 deg C and feels like 21 deg C. Environment Canada is reporting the temp as 33.5 deg C and with the humidex 37 deg C. - slightly off
      My Lat and Long for Ottawa are at 45.41117, -75.69812 which is accurate.
        There are some other issues with WU as well, which is why I am working on another source of weather data to add as an option in weatherXML.
        Jeff Farmer
        HS 3, HSPhone
          Originally posted by CFGuy View Post
          Couple of things
            Robert
              Hi just to let you know that the plugin of environnement canada works very good better than weatherxml.
              thx
                WU is getting to the point that it doesn't even agree with itself! It is becoming usual to find different data on, say, the "Today" and "Hourly" screens, for the same time period.
                10 day precipitation prediction is predictably and insanely wrong.
                I, for one, am *seriously* looking forward to CF's option "B."
                Enabled Plug-Ins
                3.0.0.6: AK Smart Device 3.0.1.9: AmbientWeather 2.0.63.0: BLBackup 3.0.55.0: BLGData 3.0.38.0: BLLock 2.0.26.0: BLUPS 3.2.0.1: Device History 3.0.0.73: EasyTrigger 3.25.614.1: HSBuddy 3.1.0.22: MeiHarmonyHub 3.1.0.2: SDJ-Health 19.10.7.1: TPLinkSmartHome 3.0.6681.34300: UltraCID3 3.0.6644.26753: UltraLog3 3.0.6554.33094: UltraMon3 3.0.5960.36744: UltraSighthoundVideo3 3.0.7806.23606: UltraWeatherWU3 3.0.2.0: Z-Wave
                  WU has a lot of problems and I think it is going to get worse as IBM continues "To improve our services and enhance the relationship with our users" by discontinuing free API keys, etc. We need another option for sure.
                  https://apicommunity.wunderground.co...nd-api-changes
                    thx
                    Great to hear. Thanks to Greg (Wadenut) for this - I actually use both. I take immediate YOW data into MCSSprinkler but use Jeff's excellent plugin for forecast information. I'm sure he'll work out a better solution as WU goes black.
                    Robert
                      using ssl for downloads
                      Hi Jeff,
                      I noticed in the log when I have issues the plugin is downloading data from http and not https.
                      Jul-10 11:03:38 weatherXML Error downloadFile: WU Forecast from: http://api.wunderground.com/api/apinumber/forecast10day/geolookup/tide/rawtide/planner_07110718/lang:EN/q/LAT,-LON.xml. Error: The underlying connection was closed: An unexpected error occurred on a send.
                      Is there a way the plugin can download from https instead? It seems to work every time when done manually. It might help while working on a solution to WU.
                      Michael
                      HS3Pro & HS4Pro on Win2012R2
                      Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
                      BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
                        Hello,
                        it looks like my scripting problem with EDF for the tempo
                        I forced TLS 1.2 on my HS3 server and it works since
                        https://stackoverflow.com/questions/...ll-connections
                        Jean-Francois.
                          Originally posted by Jobee View Post
                          Hi Jeff,
                          Michael
                          In the HomeSeer Hs3/config/weatherXML directory, open the file weatherinfo.ini.
                          Look for a section with the heading
                          [wuCommon]
                          If it doesn't exist go to the bottom of the page and add this
                          [wuCommon]
                          wuURL= "https://api.wunderground.com/api/"
                          If It does exist then edit or add the wuURL value.
                          After you add it, save the file and go to the Plugin manage page.
                          Disable weatherXML and then restart it. This step has to be done as the ini files are only read on initial startup of the plugin.
                          The next time your weather underground schedule runs, it will use the above URL to start building the download url.
                          Jeff Farmer
                          HS 3, HSPhone
