Originally posted by techguy76
View Post
Forecast icons missing
I'm having the same issue with icons not showing up from DarkSky. I downloaded Curl and put in them in the specified folder, but i'm still not getting an icons on the user page. Is there something else i need to do to kick this off so it grabs the icons? I've restarted the plugin and homeseer, and that didn't help either.
Originally posted by AttilaHooper View PostDid you follow my previous post to download curl and certificate file in the correct folder?
So, if this works, and I suspect it will since some of the icons have already populated, other folks should, regardless of the (windows) operating system:
download Curl from here,
and unzip the .7z file (if needed, the unzip utility is found here),
and move or copy the .exe and .cert files to C:\program files\homeseer hs3\bin\weatherxml\
Thanks a lot for your help!
PS
For the geekier folks out there, here's the rundown on what Curl is about!
Did anybody solve this? I'm on win10 and I have no NOAA icons, either....
And the link is broken.
This looks like the problem I'm having, but the link in Jeff's reply is a dead link, so not really sure how to proceed.
Windows 10 Pro HS3 Pro
Thanks very much - downloading curl from winampplugins.co.uk/curl and placing the exe and cert files in c:\program files\homeseer hs3\bin\weatherxml did the treat.
What version of windows are you using? If you are running XP then check this thread to see if it helps.
https://forums.homeseer.com/forum/3r...topped-working
Using NOAA wx I don't see the wx icons. For example m_scttsra.png is my forecast icon today, but it was not downloaded and not in the images/weatherXML/condition/ folder.
Edit: upon further investigation I see wxXML downloading the icons, but the icons do not show up in the condition folder.
i.e. from log
Save forecast image to: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\m_scttsra.pngLast edited by AttilaHooper; July 27, 2018, 02:32 PM.Tags: None
