Need help turning on alerts
    I have never been able to get alerts to work and need some help. I am using v.3.0.0.88 with Win 10. Everything is checked off on the Alerts page as required. I have devices that look as follows and can't figure out how to turn the alert to "on." Thanks, Elliott
    Make sure you setup your alert setting on the alert page, and then you use the Alert Triggers to make things happen. post a screen shot of your Trigger page. If you can, list out what you have setup in the Alert Settings for Severity Options. If this is not set correctly, nothing will happen.
    Michael
    HS3Pro & HS4Pro on Win2012R2
    Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
    BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
      Michael
      Michael:
      Thanks for the response, which prompted me to look deeper into the Alerts setup. I may have figured out the issue. Look at this screenshot:
      For each level of severity the Start and End times were 6:00 AM as in the first row ("Extreme"). I have made the changes for Start (12:01 AM) and End (11:59 PM). We'll see if this was it.
      Elliott
