Object Reference Error
    Started to receive the following errors:
    Aug-28 07:07:27 weatherXML Error setTiedLastUpdate: Object reference not set to an instance of an object.
    Aug-28 07:07:27 weatherXML Error wXMLForecastINI: Object reference not set to an instance of an object.
    Aug-28 07:06:06 weatherXML Error saveTideDict: Object reference not set to an instance of an object.
    Aug-28 07:06:06 weatherXML Error wXMLForecastINI: Object reference not set to an instance of an object.
    Aug-28 07:04:46 weatherXML Error setDay4ToClear: Object reference not set to an instance of an object.
    Aug-28 07:04:46 weatherXML Error wXMLForecastINI: Object reference not set to an instance of an object.
    Aug-28 07:03:22 weatherXML Error Exception in LOG of weatherXML: Object reference not set to an instance of an object.
    Aug-28 07:03:22 weatherXML Error callSpeak: Object reference not set to an instance of an object.
    Not sure if I need to restart the plugin or if there is a different issue. On version 3.0.0.88
    Michael
    HS3Pro & HS4Pro on Win2012R2
    Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
    BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
    Check to see if the ini files have gotten corrupted.
    Jeff Farmer
    HS 3, HSPhone
      Jeff:
      I'm seeing the same kind of error messages whenever HS speaks a weather alert. How do we know if the files are corrupted? I looked at hspi_weatherXML.ini, and I didn't see any odd characters, or anything that looked odd...
      BBB
        Ok - I think I see where the problem was. In my Alert Trigger I had set a Speaker Client that no longer exists; hopefully that will eliminate the errors.
        BBB
