editing weatherinfo.ini didn't change /free/v2/weather.ashx? to /premuim/v1
    For some reason even after edit weatherinfo.ini /Homeseer HS3/config/weatherxml/ from
    http://api.worldweatheronline.com/free/v2/weather.ashx?
    http://api.worldweatheronline.com/pr.../weather.ashx?
    I'm unable to get the download to work
    I did had the plugin disabled when making the edit then enabled the plugin then manually ran the schedule download and I'm getting the following error in the logfile
    ownloadFile: WWO Weather from: http://api.worldweatheronline.com/fr...d0bXXXXXXXXXXX. Error: System.Net.HttpWebResponse The remote server returned an error: (403) Forbidden.
    I then copy the link to my browser and changed it to /premium/v1 and this did work.
    Is there another file that I need to edit?
    weatherxml ver:
    3.0.0.88
    Thank you
    Mk
    I don't have a premium World Weather Online account but based on the URL you posted above try using this.
    In the weatherinfo.ini add this:
    [wwoCommon]
    wwoDownloadURLCur1=http://api.worldweatheronline.com/premuim/v1/weather.ashx?q=
    If you already have a wwoCommon section then just edit the key wwoDownloadURLCur1 to be the above string.
    Jeff Farmer
    HS 3, HSPhone
      Thank you, Sir
      Things are now working again.
      After looking over the line you sent for some reason ur was missing in (
      wwoDownloadURLC1)
      I think I saw this noted in another post and was sure I checked it twice.
      My bad
      Thank you, again for your support
