Error when Schedule runs
ID:	1258959 I've recently started using this plugin again. I'm getting this error every time a Schedule runs. I don't see anything obviuosly wrong. Judging from the times in the log it seems to occur with more than one Schedule.
    Can you help me with where to look? I really don't like red in my log...!
    Michael
    HS3, W10 Home, HSTouch, W800, Z-Stick+
    This from the Replacement Variables page might somehow be relevant.
    Michael
      Go to the Settings tab in weatherXML and set the logging level to Debug. Run the Condition schedule and then check the log and the errors above should have lots of other entries between the errors. Paste the log entries into this thread.
      Jeff Farmer
      HS 3, HSPhone
        Auto Update Refresh
        Date/Time Pri Type/Error Message/Source
        Nov-21 6:46:13 AM weatherXML Triggers to Check: 1
        Nov-21 6:46:13 AM weatherXML Check Condition Triggers
        Nov-21 6:46:13 AM weatherXML NOAA Weather Current Conditions Finished
        Nov-21 6:46:12 AM weatherXML Output XML
        Nov-21 6:46:12 AM weatherXML Create Image
        Nov-21 6:46:12 AM weatherXML Check to see if DB is being used. Save the data is set to Yes.
        Nov-21 6:46:12 AM weatherXML Set selected Speak Devices String
        Nov-21 6:46:12 AM weatherXML All Done
        Nov-21 6:46:12 AM weatherXML Set INI
        Nov-21 6:46:12 AM weatherXML wXMLHSTouchRef finished
        Nov-21 6:46:12 AM weatherXML Check for refID: -1
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Data Provider
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Barometer Direction
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Barometer Dir
        Nov-21 6:46:12 AM weatherXML Set Baromter: 30
        Nov-21 6:46:12 AM weatherXML Number returned: 30
        Nov-21 6:46:12 AM weatherXML Number rounded: 30
        Nov-21 6:46:12 AM weatherXML Number converted for region setting: 30.07
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Solar Radiation
        Nov-21 6:46:12 AM weatherXML Set Solar Radiation:
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Visibility
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Visibility
        Nov-21 6:46:12 AM weatherXML Set Visibility: 10
        Nov-21 6:46:12 AM weatherXML Number returned: 10
        Nov-21 6:46:12 AM weatherXML Number rounded: 10
        Nov-21 6:46:12 AM weatherXML Number converted for region setting: 10
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Dewpoint
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Dewpoint
        Nov-21 6:46:12 AM weatherXML Set Dewpoint: 70
        Nov-21 6:46:12 AM weatherXML Number returned: 70
        Nov-21 6:46:12 AM weatherXML Number rounded: 70
        Nov-21 6:46:12 AM weatherXML Number converted for region setting: 70
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Humidity
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Humidity
        Nov-21 6:46:12 AM weatherXML Set Humidity: 100
        Nov-21 6:46:12 AM weatherXML Number returned: 100
        Nov-21 6:46:12 AM weatherXML Number rounded: 100
        Nov-21 6:46:12 AM weatherXML Number converted for region setting: 100
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Wind String
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Wind Speed
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Wind Speed
        Nov-21 6:46:12 AM weatherXML Set Wind Speed 5
        Nov-21 6:46:12 AM weatherXML Number returned: 5
        Nov-21 6:46:12 AM weatherXML Number rounded: 5
        Nov-21 6:46:12 AM weatherXML Number converted for region setting: 5
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Wind Gust
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Wind Gusts
        Nov-21 6:46:12 AM weatherXML Set Wind Gust:
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Wind Degrees
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Wind Degrees
        Nov-21 6:46:12 AM weatherXML Set Wind Degrees: 330
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Wind Direction
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Wind Direction
        Nov-21 6:46:12 AM weatherXML Set Wind Direction: Northwest
        Nov-21 6:46:12 AM weatherXML Wind Dir
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Condition Icon
        Nov-21 6:46:12 AM weatherXML Check for replace with
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Condition
        Nov-21 6:46:12 AM weatherXML Save to: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\nfew.png
        Nov-21 6:46:12 AM weatherXML Downloading the weatherXML: curcond.jpg file at http://forecast.weather.gov/images/wtf/small/nfew.png.
        Nov-21 6:46:12 AM weatherXML Replacement URL: http://forecast.weather.gov/images/wtf/small/nfew.png
        Nov-21 6:46:12 AM weatherXML Save condition image to: C:\Program Files\HomeSeer HS3\html\images\weatherXML\condition\curcond1.jpg
        Nov-21 6:46:12 AM weatherXML Download image: http://forecast.weather.gov/images/wtf/small/nfew.png
        Nov-21 6:46:12 AM weatherXML saveIconCondition: http://forecast.weather.gov/images/wtf/small/nfew.png
        Nov-21 6:46:12 AM weatherXML Set Condition: A Few Clouds
        Nov-21 6:46:12 AM weatherXML Condition
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Temperature
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Temperature
        Nov-21 6:46:12 AM weatherXML Set Current Temp: 70
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Feels Like
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Feels Like
        Nov-21 6:46:12 AM weatherXML Set Feels Like: 70
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Todays Low Time
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Low Temp
        Nov-21 6:46:12 AM weatherXML Check Low Temp
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Todays High Time
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Hi Temp
        Nov-21 6:46:12 AM weatherXML Number returned: 75
        Nov-21 6:46:12 AM weatherXML Number rounded: 75
        Nov-21 6:46:12 AM weatherXML Number converted for region setting: 75
        Nov-21 6:46:12 AM weatherXML Set Daily High Low
        Nov-21 6:46:12 AM weatherXML Temp
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST StationID
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Location
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Updated Time
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 HST Updated Date
        Nov-21 6:46:12 AM weatherXML Check if this address exists: Location 1 Updated
        Nov-21 6:46:12 AM weatherXML Set Updated: Nov 21 2018, 5:53 am
        Nov-21 6:46:12 AM weatherXML Set Devices
        Nov-21 6:46:12 AM weatherXML Solar Radiation sent:
        Nov-21 6:46:12 AM weatherXML Number converted for region setting: 10.00
        Nov-21 6:46:12 AM weatherXML Visibility sent: 10.00
        Nov-21 6:46:12 AM weatherXML Number converted for region setting: 70.0
        Nov-21 6:46:12 AM weatherXML Dewpoint sent: 70.0
        Nov-21 6:46:12 AM weatherXML Humidity sent: 100
        Nov-21 6:46:12 AM weatherXML Wind String sent: Northwest at 4.6 miles per hour (4 KT)
        Nov-21 6:46:12 AM weatherXML Number converted for region setting: 4.6
        Nov-21 6:46:12 AM weatherXML Wind Speed sent: 4.6
        Nov-21 6:46:12 AM weatherXML Wind Gust sent:
        Nov-21 6:46:11 AM weatherXML Current Condition: A Few Clouds
        Nov-21 6:46:11 AM weatherXML Number returned: 70
        Nov-21 6:46:11 AM weatherXML Number rounded: 70
        Nov-21 6:46:11 AM weatherXML Number converted for region setting: 70
        Nov-21 6:46:11 AM weatherXML Feels Like sent: 70
        Nov-21 6:46:11 AM weatherXML Number converted for region setting: 70.0
        Nov-21 6:46:11 AM weatherXML Temperature sent: 70.0
        Nov-21 6:46:11 AM weatherXML Set Array
        Nov-21 6:46:11 AM weatherXML Wind String: Northwest at 4.6 miles per hour (4 KT)
        Nov-21 6:46:11 AM weatherXML Check wind direction values.
        Nov-21 6:46:11 AM weatherXML CalcFeelsLike: 70
        Nov-21 6:46:11 AM weatherXML calcValueFeelsLike: 70
        Nov-21 6:46:11 AM weatherXML calcValueFeelsLike: Temp: 70, Wind Speed: 4.6
        Nov-21 6:46:11 AM weatherXML Start the forumlas
        Nov-21 6:46:11 AM weatherXML Calculate Feels like for location 1
        Nov-21 6:46:11 AM weatherXML FeelLike:
        Nov-21 6:46:11 AM weatherXML sUnit: F
        Nov-21 6:46:11 AM weatherXML Loc Unit: F
        Nov-21 6:46:11 AM weatherXML sTempUnit:
        Nov-21 6:46:11 AM weatherXML Provider: noaa
        Nov-21 6:46:11 AM weatherXML Check for any needed conversions.
        Nov-21 6:46:11 AM weatherXML Check for new conditions
        Nov-21 6:46:11 AM weatherXML Check Provider
        Nov-21 6:46:11 AM weatherXML Finished importing weather current information from NOAA.
        Nov-21 6:46:11 AM weatherXML Cond icon: http://forecast.weather.gov/images/wtf/small/nfew.png
        Nov-21 6:46:11 AM weatherXML Checking Wind Dir: Northwest
        Nov-21 6:46:11 AM weatherXML Checking Humidity: 100
        Nov-21 6:46:11 AM weatherXML UnitTemp:
        Nov-21 6:46:11 AM weatherXML heatIndex:
        Nov-21 6:46:11 AM weatherXML windChill:
        Nov-21 6:46:11 AM weatherXML Temp Unit: F
        Nov-21 6:46:11 AM weatherXML The file C:\Program Files\HomeSeer HS3\Data\weatherXML\NOCondition1.xml is ready for import.
        Nov-21 6:46:11 AM weatherXML Download Status: Success
        Nov-21 6:46:11 AM weatherXML Downloading the NOAA Weather Condition file at http://w1.weather.gov/xml/current_obs/KFLL.xml.
        Nov-21 6:46:11 AM weatherXML Replacement URL: http://w1.weather.gov/xml/current_obs/KFLL.xml
        Nov-21 6:46:11 AM weatherXML Download: C:\Program Files\HomeSeer HS3\Data\weatherXML\NOCondition1.xml
        Nov-21 6:46:11 AM weatherXML Download and Import
        Nov-21 6:46:11 AM weatherXML Reset Hi Low
        Nov-21 6:46:11 AM weatherXML wXMLCurrent: Running current location 1
        Michael
          On the weatherXML scheduled page, please check and see which type is running at 1 minute after the hour. "Conditions, Forecast, Hourly,"
          Jeff Farmer
          HS 3, HSPhone
            Forecast
            Regards
            Michael
            Michael
              Sorry, I haven't been around much lately. Since the forecast is running when you get the error, I should have had you grab the log when the forecast runs. Set the logging level to debug and run the forecast schedule. Grab the log entries and get them to me.
              Jeff Farmer
              HS 3, HSPhone
