WWO url setup
    WWO url setup
    Hi,
    I am currently trying to move from WU to WWO., using 3.0.093 version of plugin.
    I got this errorkey has been replaced with xxxx)
    downloadFile: WWO Weather from: http://api.worldweatheronline.com/pr...xxxxxxxxxxxxxx. Error: System.Net.HttpWebResponse Le serveur distant a retourné une erreur : (404) Introuvable.
    Looking at the WWO site, i can see that the url given in the premium-api-explorer.aspx page is :
    http://api.worldweatheronline.com/pr...&num_of_days=5
    wich mainly differs using v1 instead of v2.
    Replacing v2 with v1 in the url shown in the error turns to be OK.
    Am I doing something wrong ?
    Pierre
    Check in the HomeSeer HS3/config/weatherXML/weatherinfo.ini
    Look for:
    [wwoCommon]
    wwoDownloadURLCur1=
    wwoDownloadURLCur2=
    wwoDownloadURLCur3=
    If they are there than delete all 3 of the ini keys. These are provided to override the URL hard coded in the app. But if the URL changes these settings will still tell the plugin to use their values. The URL coded into the plugin is:
    http://api.worldweatheronline.com/pr...12&key=YourAPI
    Make sure that you are on the lastest version of wxml as this url change was fixed recently.
    Jeff Farmer
    HS 3, HSPhone
      Thanks a lot
      All set now
