Two errors in my Log file from WeatherXML
  • Two errors in my Log file from WeatherXML
    Hi,
    Just listing the two errors I see when using WeatherXML. In reading this forum it looks like the missing file issue has been reported but the other may be new. I see the second error about every hour and suspect that some data is missing from NOAA. I am using version .93 of the plugin and the latest HS3 for raspberry pi. Thanks
    Mar-04 8:36:59 AM Warning File does not exist: /usr/local/HomeSeer/html/images/weatherXML/condition/i=hi_shwrs&j=few&ip=10.png
    Mar-04 8:01:02 AM weatherXML Error setForecastDataArray: Method 'System.String[].Set' not found.
    I modified the code for NOAA to remove the = and & from the name of the image. I can't post the fixed version until I get finished testing the new provider, Dark Sky.
    but it will be in the next version posted.
    Jeff Farmer
    HS 3, HSPhone
      Hi Jeff,
      No problem I was just reporting it was still there with version .93 and that every hour the C# error happens since something is missing in the NOAA data dealing with forecast data.
      Thanks for the response.
        I am also getting the second error in my log.
        Mar-14 9:04:01 AM weatherXML Error setForecastDataArray: Method 'System.String[].Set' not found.
        Occurs everytime the forecast schedule updates.
          This seems to be a Linux vs Windows error that I can't duplicate. I am working with another user to find a fix for this.
          Jeff Farmer
          HS 3, HSPhone
            Jeff:
            I'm seeing a load of
            ConvertValues Speed: Method 'System.String[].Set' not found.
            entries in my log as well - I'm assuming it is a Linux problem based on your previous post?
            Paul
              Yes, it only happens on linux installs. I have been trying various things to fix it but don't have a way to test it so it is slow going.
              Jeff Farmer
              HS 3, HSPhone
                Jeff:
                Let me know if you need another Linux “guinea pig” for debugging.
                Paul
                  Will do. It will be Thursday evening before I have time to work on more changes.
                  Jeff Farmer
                  HS 3, HSPhone
